Hinging Inca spring
jdm
This has been discussed already but I will restrict it to a simple question. Any real chances of bringing it in place with upsetting the block?
I was thinking of keeping the spring vertical with rodico and place it diagonally in the opening.
Not fun and not easy considering  the need to do this within a clear bag.
Hi!
This happens sometimes. You need to reinsert diagonally one leg at a time very carefully. Under magnification works best. I would personally do this with fine tweezers, not actually holding the spring, but working the ends in carefully as it rests on the Incabloc.
1 minute ago, DrG said:
Hi!
Forgot to mention that there is a very high probability that the clip will fling out a couple of times.
Funny I just did one of these they can be a pain. Was I did was to hold the the spring vertical with my  tweezers  with the tabs in line with the grove then I turn my movement holder a 1/4 turn and it felt right in. You have to remember they enough room to do this since the spring with hing up for service. I did do this work under my microscope.
OK, it went in. First i cut an hole in adhesive tape which I placed to cover That is essential unless you like the spring to enter the movement at some point. The spring wouldn't go all the way down vertically, the chamfers made it jump all over the place. Looking carefully I saw some space on both sides of the cut, just above the regulator ring, so I placed the spring horizonally with the smallest moves pushed it toward the center. Next drama was removing the tape without touching the spring. Oh well.
is this a Chinese clone or original? the reason for the question is the Chinese skip one of the manufacturing steps. If it's an original spring it is not supposed to come out typically without disassembling the setting. on rare occasions you will have an original one does come out and then it will go back in usually with difficulty.
Genuine ETA in an Oris. Google for Incabloc images to see what great variety of shapes the block can have. From that I suppose that some are more prone to the problem. And the microscopical hinges may not be 100% perfect.
Give me Seiko Diashock everyday, really.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
    • No thats straight out of the watch as i found it the balance wheel is almost as bad. I've never seen so much material removed.
