gruen 730 ss
gary17
Hey guys.
Anyone know anything about these gruen mainspring barrel set up
The arbour is attached to the barrel lid and spins .
Before i attempt to remove the arbour i thought i better check to see if that's the wrong way to go.
The problem is you cannot see when the mainspring is attached to to arbour.
And i have tried a number of times, sometimes it feels as if its caught. ( it stiffens to turn) so you start to rebuild the watch and hey and behold its not caught at all when winding.
so any thoughts. cheers
gary
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
    • If the oil drop was freely standing on an epilame treated cap jewel it could easily slide off if you knocked the watch hard but the balance pivot keeps it in place.
    • Latest 404 is this Baron which has a copy of a Seiko 66B movement in it, handy when I needed to find a replacement setting lever. Apart from the setting lever, crown, stem and new crystal (original was cracked) the watch is original. Finished result:
