Hi everyone,
Appreciate your kind advise on installing bezel fit Dom acrylic crystal
The problem is when I sit the crystal in the press die, the die is not deep enough to touch the bezel. Photo attached.
In this case how should I proceed?
Should I remove the Dom crystal, press on the bezel to the watch case then lastly press in the crystal?
Kind regards
Jin
You could remove the crystal and fit the bezel first.
Or, try it like you have if it’s not too much force required to press - acrylic crystals can take a lot of pressure if it is correctly applied near the edge.
Hi rodabod, I afraid the acrylic crystal will break as the contact point is at the centre of the cystal. Are there special dies for Dom crystal? Or what's the normal practice for such situation.
Ah, I guess it must be quite a deep crystal. I had a similar issue with a Tudor crystal with cyclops magnifier, so had to modify the crystal press cup.
Do you have a crystal lift?
Unfortunately I do not have crystal lift tool. Did u used crystal lift tool to compress the crystal and fit it right into the bezel?
Yes, exactly.
Is your movement a front-loader or does it fit in from the rear? The other option would be to use your crystal press to compress the new crystal and fit it to the bezel when the bezel is fitted to the mid case, but with the movement not yet fitted.
7 hours ago, rodabod said:
Yes, exactly.
It's a front loader so it tricky ?
Ok. I would either make a new cup (section of nylon pipe pressed with a flat attachment?), or I would use a crystal lift (claw) to fit the crystal separately. I would recommend getting a second-hand Swiss crystal lift if you have the money.
Crystal lift I saw a few on AliExpress at middle price range.
Thank you rodabod for the kind advice.
Regards
If you intend to use the AliX crystal lift only rarely, then go for it.
I got my first crytal lift from Alix. It lasted only a few times before noticed that I required more and more force to tighten the crystal sufficiently to remove it. I took the crystal lift apart to find out why.
The jaws of these China made crystal lifts are made of aluminum. Just after a few uses, the rim of the body will leave indentations on the jaws. The next time you remove a crystal with the same diameter where the indentations are, the rim of the tool gets caught in the depressions and you'll need a lot more force to close the jaws beyond it.
The Indian made ones fair a little better. The jaws are made of brass and don't suffer damage after each use. But the center hub is made of aluminum which can distort after some time.
So Rodabod's advice of getting a 2nd hand Swiss crystal lift is good advice.
Hi, I'm considering using crystal press to press back the crystal, I'm not sure if it will work ?
On 9/24/2020 at 3:01 PM, Jin999 said:
Hi everyone,
Kind regards
Jin
Some update on the progress.
The bezel assembly with domed crystal can be press to the watch case by hand without any tools.
Job done and thanks everyone for the sharing their experience, appreciated.
Kind regards
Jin
    • Regarding the spring winders, I made my own and used copper pipe reducers as the tubes to retain the spring. You will need to cut out a section for the end of the spring to protrude but if you watch one of the many videos on this subject that will make sense. You can find a selection of sizes on Ebay for very little cost. I'll attach a pic showing one of mine.  Good luck!
    • There were things bothering me about this discussion that took me a while to figure out the problem. In the image below it appears to be the spring may be pushing up? Normally when Omega has a spring pushing up the pinion has a pivot with a bridge to hold it in place so in other words the spring can push on something that stationary as opposed to this which appears to be floating? To understand the problem with the above image we need another image of side view which I have below. In my image down below on the left-hand side it agrees with the image up above. But the only problem is the left-hand side is defective and the right-hand side image is the way it's supposed to look. Then Omega if you can access the right documents does explain how and why this problem occurs. With the pinion floating around it might be assumed that you support it when putting on all the hands but you do not because as noted below if you do this small bush on the pinion will relocate out of position exactly what we see in the image up above.   Then Omega does not mention this but there is a possibility of also damaging the pinion and causing the bush to move to where it's not supposed to be when removing the hands.
    • Maybe show us 1) the watch, 2) timegrapher readings in DU, DD, PU, and PD.
    • The timegrapher displays significant beat error variations in the dial-up position. When the watch is lying flat (face up), the beat error is much higher than in other positions. Beat error readings are inconsistent, with especially large gaps in the face-up position.  Please help !
    • Looks like an open-access journal that runs as a glorified pre-print server with no true peer review, so it’s not easy to judge the veracity of the conclusions.
