How to improve beat error on an Omega 601
DanB
Hi all,
Just serviced this Omega Cosmic (the one I asked about crystal installation recently) and I'd like to improve the beat error before I close it up. From what I can tell through physical inspection, and from what I have read, it looks like the stud holder should be movable, but it won't budge when given a nudge. I gave it multiple stronger pushes and still no luck (well, I think it moved a minuscule amount because the beat error went down by .1 milliseconds). It's an excenter regulator. I want to avoid much manipulating of the balance assembly - particularly the hairspring - to avoid any disaster. I can live with 1.2 milliseconds of beat error, but before it goes back into the monocoque case, I'd like to give it one more try if possible.
Thanks!
always nice if you would give us a picture of the problem just to avoid any complications. then if you really want accurate amplitude measurements it would help if you had the correct lift angle which is 49.0. looking at the parts list the stud holder is definitely movable but it still be nice for us to see a picture because normally shouldn't have to lubricate them.
Thanks for the suggestions. I'll have to build up the nerve to disassemble the adjuster assembly, though I think I can take this project on in phases; remove the hairspring first, then see if the arm holding the stud can be coaxed. I know what direction it should go. The balance assembly has been throughly cleaned both with L&R Extra Fine in the electrosonic and a soak in One-Dip. I'll include a photo of the assembly if I take the next step.
Here's the balance assembly with balance complete removed. I tried moving the beat regulator with the balance off but had no luck. It made me think this really wasn't intended to be moved since I applied a fair amount of force, but Omega in its 551 technical guide it says it should (different balance assemblies for each movement but same design on the underside). I'm guessing that the U-shaped spring (Omega calls it a "bolt") has to be slid out, freeing up the regulator arm. Then I could apply a tiny bit of lubricant to where the spring slides back in and test the regulator arm movement before replacing the balance.
Given my previous experience with working with balance assemblies - ruining two on two inexpensive watches - I have some serious hesitation disassembling this one. In those situations it was the hairspring that was the victim. Removing the hairspring on the Omega was relatively easy, so that is safe for now. My worry is the difficulty I may encounter putting that spring/bolt back into place. It's easier to say goodbye to a $25 watch (my previous blunders), not so much an Omega.
Any words of advice will be appreciated.
I have an image for a different Omega but they should all be the same. As you noted you slide out the little U-shaped clip. Then the whole thing comes apart just pay attention to the order in which it goes back together. I have an image that should help you.
then it might be in my imagination but is your stud holder bent?
Hi John,
Yes, that's the image I have as well. Very helpful. I don't think the stud holder is bent - it could just be the angle at which I took the photo. But I will look more closely at it.
So that U-bolt holds the whole works together? That means everything comes apart, including the rate regulator, etc.?
Well, clearly I have not taken one of these apart down to the studs, so to speak. I think I'll practice with a couple balance assemblies I have lying about, then see if I have the nerve to tackle this one.
Thanks again for all the suggestions.
I practiced on a Hamilton 661 balance assembly (has an excenter regulator like the Omega 601), took it apart, and it was a chore to get that u-bolt spring reinstalled. I got it back together, but I think the bottom of the incabloc setting suffered a bit as a result. That made me take a closer look at the Omega, and John was correct - there is a bend (two bends actually) in the bottom of the incabloc setting (similar to what I did to the Hamilton), photo attached. That could be what kept the beat regulator from moving in the first place. Rather than take that apart and potentially make matters worse when reinstalling the u-bolt, I switched balance assemblies with an Omega 550 movement I have (I checked the Jules Borel database and both movements use the same one). That got the beat error on the Omega 601 from about 1.4ms to about .4ms. Then I successfully adjusted the Omega 550's beat error from 1.4ms to .7ms - plenty good enough - by nudging the regulator arm. It did nudge, but I've got to say, it's hard to move which makes sense given how much resistance that u-bolt spring provides. You don't even perceive it moving, but the change shows up on the timegrapher.
A long winded way to give you all an update and to once again express thanks to all that took the time to weigh in.
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
