Oil filled watches
yankeedog
Hello all,
Of late I have noticed that some folks have taken to filling their quartz  watches with oil. Either mineral  or silicone. In an effort  to increase their water resistance  by making them incompressible.I am also thinking I could not hurt to have the movement  immersed  in lubricant. Does  anyone  have any experience  doing this? Please  opine.
The real reason is to be able to see the watch underwater at angles without distortion. Silicone oil is the way to go as mineral can disintegrate plastic parts. Really unless youre a scuba diver its really not worth the effort as any future work will require extra work. Also once its filled theres no turning back without a complete restoration.
Sent from my SM-G950U using Tapatalk
did you notice if you go to YouTube where the video is the comments have been turned off? Always suspicious when I see a video or you cannot comment.
to get a better understanding I found a company that's doing it. Notice if you look at their link below the reference to mechanical watches can't be used because too much friction of trying to run in the fluid.  this is an interesting comment because quartz watches are even more susceptible to friction than mechanical watches. My suspicion is they designed a special quartz watch plus the reference to the lithium battery they probably have a super large battery to make up for all the energy loss of trying to drive the secondhand through a fluid. Also a note they don't actually say what the fluid is but I suspect that it's probably superlight fluid. So all the hobbyists filling their watches with mineral oil are going to get a very short running time.
https://www.sinn.de/en/HYDRO.htm
Thanks to all on your input.I suspect a higher  torque   movement  like maybe a ronda lithium  battery  one would be in order. What also intrigues  me is possible  increased  resistance  to vibration. I know that certain  instruments  used  in high  vibration  environments  were once oil filled.  I  ride a motorcycle  and have noticed that neither mechanical  nor  quartz  movements   can long tolerate  the vibration.  I was  wondering  if an oil filled  watch would have better  resistance  to this .opinions  please.
    • Once you have the collet closer bits off, and the pulley off, there are two nuts on the spindle. These must be removed. There is a large nut in the back of the headstock with two holes, remove this with an appropriate wrench. The front large nut comes off too. The spindle now comes out- but wait- there's more! There is a spacer between the outer races of the bearings; the spindle will almost certainly come out "assembled" with both bearings and this spacer (it can actually come out front or back-ways with the large nuts off the headstock). You have to manage to press out the spindle from the rear bearing, get the spacer off, then remove the front bearing, now you can get to the key.   Imagining you get it all apart without causing any damage to the bearings, now the fun part starts. You must apply preload to the bearings, and this is a very tricky endeavor. Basically once you have the bearings back on, and are in the casting, you snug up the rear nut (one of the two) on the spindle, checking the play of the spindle with at least a 0.002mm reading indicator, until there is zero axial play, then just a little more, then snug up the second nut to lock things in place. Of course snugging up the second nut influences the preload, so you can go back and forth a few times to get it right. Too much preload and bearing life diminishes, too little, and you get poor performance, poor surface finishes, ball skidding, etc.   When I replaced the bearings in one of mine many years ago, I was surprised to find that the bearings were regular deep-groove bearings, but of a higher precision class than normal. I replaced with dimensionally identical angular contact bearings, class P4. In trying to set the preload, I just about lost my mind, so called Barden (the high precision arm of FAG bearing makers, and who made my new ones) and a nice engineer told me that the folks at Leinen were either crazy, or really good- he also said it's 100% A-OK to set up deep groove bearings with preload like this, but best is angular contact. In this bearing setup, the standard way to do it is to have a spacer between the outer races, and another between the inner races. Leinen has the former but not the latter, haha. His advice was to make an inner spacer. The trick is it has to be the exact same length as the outer spacer, within like a micron.  Then you just tighten everything up and the preload is set, because the bearings (the new ones) are ground in a way that they have proper preload in that situation. Easy. Sort of- if you have the means to make the other spacer!   Just to note- Schaublin does the preloading as Leinen did on these on their lathes using angular contact bearings. There is a procedure in the manual, where you tighten the nut until axial play is zero, then a certain number of degrees more. This works on their setup as the nut itself locks without a second nut, and they spent the time to figure it all out in a repeatable way.   I say all this not to scare you off from dismantling your headstock, just to give a heads-up what you're up against to get it back to where it was before.
    • Do, write a nice letter to Santa. I do all disassembly and assembly under the microscope. I consider it a necessity.
    • Yes Breguet overcoil, and A is OK, the damage is from B to the end. It should look lile this. The studd is fixed by the screw head into  the cut.
    • I opened up a 17 jeweled Swiss made movement only to find it has a pin pallet escapement. Not sure where the 17 jewels are but they ain’t on the pallet fork! Tips for lubrication?
    • Hi, This headstock is a little bit too modern for me to know my way round it. The pin that stops the collet spinning is sheared and needs replacing. Does anyone have advice on how to remove the spindle? I’m assuming that you remove the quick change assembly from shaft. Remove pulley. Unscrew front and back bearing plates on the headstock. Then press the spindle out applying pressure to the front (collet end). Has anyone done one of these? Any pictures or links to articles/literature gratefully appreciated. Thanks in advance. Warm Regards   Andy
