I restore many vintage chronographs. While there are some unique approaches in the different brands there is a common approach and lubrication is just common sense now. I am going to service a Heuer cal 12 and I could "guess" at the lubrication of this very unique chrono I would be thrilled to have a lubrication chart from a service manual if it exists.
Any help with this?
Thanks!
I think the base caliber for the Tag Hour Caliber 12 is an ETA 2892A2 so for the movement side you could just use that one.
But then the chronograph part use to be a 8510 and it isn't any special with that either, chronographs  usually isn't that hard to lubricate, just in case your calibre 12 also has this module i can paste the lubrication procedure.
Edited by HSL
swinglish
I have a confusion found some links below no lubrication guides no service manuals and one of them appears to be different than the rest? As far as lubrication goes just find a modern chronograph and follow those suggestions.
https://thewatchbloke.co.uk/2018/09/22/heuer-calibre-12/
https://watchbase.com/tag-heuer/caliber/calibre-12
https://watchguy.co.uk/repair-heuer-autavia-buren-12/
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Heuer_12
The base movement was a Buren/Hamilton, and the rest was a mix of Hamilton, Breitling, Heuer, and Dubois Depraz doing the module. There's a good write up on the history at Hodinkee https://www.hodinkee.com/articles/chronomatic-heuer-breitling-hamilton-50th-anniversary
Interestingly in some service literature I've seen they recommend cleaning the module assembled. Since these are all 40 something years old it's best to ignore that and disassemble for cleaning. There are a couple of thin springs in the winding system that really like to disappear. The rotor assembly is not meant to be taken apart, and it's tricky getting oil in to the axle but very important. The click for the auto reversers has a long fragile spring that needs to be carefully managed. Overall it's down on my list of movements I like; I think it was a case of "too many cooks"- but they do work well.
I was a bit tired when writing yesterday night and I see it is a bit unclear, a lesson learned, never sleep and write.
Yes there are two different versions of what sometimes is called Calibre 12 one vintage and one modern.
The vintage (which I assume this adress based on the title) is called Chronomatic Calibre 12 and are using the chronograph module shown above 8510. The lower picture is the lubrication scheme from its Tech manual using as usual just two lubricants, Synth-a-lube (Moebius 9010) and Bergeon KT22 (Grease).
This one you can see serviced in three links from @JohnR725  Watch Bloke, Watch Guy and Ranfft and i think described by @nickelsilver
The they made a modern version based on the 2892A2 which is using a Dubois-Depraz 2008 Chronograph module.
For this one I have no lubrication shematics.
This is the link shown to watchbase.com.
3 hours ago, HSL said:
bit unclear
this is why it's helpful if the original poster would always post a photo of the watch movement they're asking about. It's not the only time we've had confusions because people either ask the egg questions without showing us the watch or hear where we have more than one watch.
then finding technical information from that seems to be nearly impossible but I vaguely recall I once found something I just can't remember why or where. They probably be helpful if we knew all the places the module has found itself attached to because that might reveal a data sheet for that watch as opposed to I don't think they give out anything other then look we make nifty modules.
is amazing when you grasp what the problem is you can find like this link
https://omegaforums.net/threads/tinkering-with-a-dubois-depraz-module.38806/
as were just looking for generic guide we find out which Omega watches have a module. The module should be more or less similar I would suggest of someone's taking a module apart take lots and lots of pictures take too many pictures.
So here's the Omega version of one of the modules complete with lubrication
4436_Omega 3220 dubois-depraz-module.pdf
Thank you everyone for the wealth of information. I am good to go. I didn't provide a photo of the watch because I didn't have it in my shop yet and I didn't know there was a modern version.
Thanks again!!!
    • I would repeat what @nickelsilver says, and even more. I have at leas 10 old thread plates and I have never seen one that will cut like a normal die. I don't know if they are completely worn or have never been sharp enough, but I find them completely useless. And, for the new Indian ones, I have heard only bad things. For sure, if one tries to cut more thread on a winding stem, this hole of the plate is ruined. Further more, I have bad experience with all watch size thread dies that I could buy from the available machine  tool shops here. They could not cut normal thread even on brass rod. The size was significantly smaller and the pitch is like it should be for the claimed size... The thread shape was bad too. I will explain how I do threads. I use lathe that can cut threads and thus I can prepare perfect taps. I use milling attachment instead cutter in the tool post and so I can cut thread even on hardened rod. But I prefer to harden the rod after thread cutting and temper it only to light color change as to have the maximum hardness. Then I make a tap out of it by grinding. I prepare my dies for screw thread cutting with the taps I have prepared as described. In watchmaking, dies exist and are often used that are not cutting, but rather forming the thread. They are like nuts and don't have cutting holes and edges. This kind of dies I prepare and use. You will need soft steel plate , drill a hole in it, then cut thread, then make chamfer on one side, repeat the thread, harden. You can temper just a little or leave untempered, depending of the steel You use. Using such die is with soft steel rod (or completely annealed). Good oil is to be generously applied. The rod has to be with smaller diam than the thread size (about 0.8 - 0.9 x ), the diam is better determined by tries. The rod elongates by the thread forming too. When I have to make screws from harder material like SS, I just cut them on the lathe. You screw needs hardening and tempering to be finished as real screw.
    • You could make a guide/jig. Cut a slot in a piece of metal approx the same thickness as the screw head, then drill a hole (screw head diameter) in that slot.
    • Tried a SR920W and its completely dead after 3 weeks 🤷‍♂️
    • Thanks so much for quick replies. I got some watch repair tools ordered, and will get back with pictures once I removed the back lid and get into it 🙂
    • Welcome to the WRT forum.
