Help Fixing Omega Chronostop - Broken Pusher Tube
Looks great Michael, just the combination of a damp cloth and iron perplexed me 😅. Steam will swell the veneer and soften any adhesive underneath. Its amazing what you can do with a little glue, filler and refinishing, good job matey 👍 -
By watchweasol · Posted
Hello and welcome to the forum attached a bit of reading for you TZIllustratedGlossary.pdf -
Hi from your description it’s only when the bridge is tightened down. Which would lead one to think the bridge is warped in some way binding the arbour. -
Hi Mike I had a tissot like that abugger to get off and on . Tighter than a crabs botty. -
Thank you for your welcomes, and thank you for the glossary - very interesting and useful. I hope I may be able to contribute to discussions soon, but that is a load of information to trawl through to see what has been discussed previously...
