By watchweasol · Posted
Hi @Michael20 I think you can get them off eBay. I use the spare ones fron ink cartridge refills, the ends are square cut but will file easy enough. @RichardHarris123 the greaseproof paper trick I believe was to remove marks using a warm not hot iron problem being not melting the veneer glue which is animal based. -
Hi @JonC I worked in York for 7 to 8 years, lived in Tadcaster at the time nice old city still got family there. -
I know Stephen there was no way i was paying out for a brand name, being yorkshire born and bred i go direct to an ingredient and hope its just one. I've had a big jewel suspended over a jar of 90° heated stearic acid for 5 hours , its time to oil it up. No idea if i reached enough temperature but it was a bit wiffy so i assume fumes were produced. -
Which was the standard for years https://de.m.wikipedia.org/wiki/Epilamisierung
