Help removing movement from case
Hi everyone,
I'm trying to remove a valjoux 7750 from a Maurice Lacroix MP 6348 and I believe it is accessed from the front of the watch.
The crown and stem are removed and the two retaining screws are out, the dial and movement rotate freely but the movement won't release.
One of the sub dial hands has come away so I'm trying to take the hand out to avoid dial damage.
Does anyone have experience with this or these watches? I know there are bezel removal tools from bergeon etc but wasn't sure if those worked on stationary bezels.
Thanks to anyone that has some insight.
So far as I know this is the type of bezel remover you need to use for that style bezel. I bought one of these to help remove rotating dive bezels (on the advice of someone) and my experience is it is poorly suited to that task, but I think it would be perfect for what you're trying to do.
I've never needed to remove a friction bezel and these pictures are from the Internet.
48 minutes ago, vinn3 said:
have you removed the bezel?  put the stem back in until the bezel is off,   if it did not go in,  you have a "dial off situation".  good luck.  vin
Haven't removed the bezel yet. The keyless works needs rebuilding as the stem won't go back in
This is the tool I thought it would need, will try and get hold of one, thank you.
Hi  The device BrianB pictured will work well enough on a stationary dial as well as the rotary version, C case knife under the bezel lip and twist will bring it off. Hold the watch in a cloth and be careful not to mark the case side. There is sometimes a small notch for the knife so have a good look round the case sides.
I've had a look through a loupe and can't see any notches. I can't work out if the bezel removes from the lip or below that where there appears to be a seam
Just tried with a case knife with a fair amount of force and there was zero give at all!
Removing bezels can be problematic if you encounter a tight one. I do own the tool suggested but it can be too brutal and if not careful ( From bitter experience) it can distort the bezel. I use a vintage butter knife. It is sharp enough to get under the bezel but being flexible you can feel the tension being applied.
However the movement should be removable without removing the bezel. Looking at the pics I would say it is a friction fitted case back
The case back is screw down, I've removed this, taken the stem out and undone the two screws that hold the movement to movement ring. The movement ring doesn't budge, it's part of the actual case, I didn't think the movement and dial could come out if the movement ring is fixed?
Ok agree looking at the pics it does not have a traditional bezel. However the movement and dial should come out unless the dial has a lip. If so then the surrounding bezel will have to be removed, Cristal removed then the movement will come out from the front.
10 hours ago, watchweasol said:
Hi   Just a thought  the bezel could be screwed on, try using a sticky ball to unscrew it.
You're an absolute genius! Never would I have thought it would be a screw down bezel. Put it upside down in a movement holder that grabbed exactly where the bezel inverts and viola! Thank you so much
That’s how the original Oyster case worked.  Those “flashy” knurled bezels, they continue to use, used to fit a tool to unscrew the bezel just like the case back.
This is the first I’ve heard of it outside Rolex.
I think Panerai continued that case assembly method after Rolex stopped using it. No idea if the modern ones still do. I believe they were using Rolex pocket watch movements as well.
Ive never handled a Panerai, so I can’t say more about dealing with them.
    • I think we are about there, if there were still lots out there then the cost of a watch from 5 years ago would be around the same as it is now (allowing for inflation). Given that the price has gone up several times over we can only assume that supply cannot keep up with demand so we must be at or past peak supply, especially if the trend continues. I see even places like Australia, Ukraine and even South America are selling watches on eBay, picking over their stocks, mixed in with fakes and Frankenwatches etc.
    • I understand the demand bit, the generation below me 30ish are too technology engrossed to own a mechanical watch and they just dont like old stuff. I also consider myself at the getting on age of 57 to be a rare find of someone that likes old stuff, i did buy an almost 100 year old book yesterday titled " The New Modern Home " printed 1929.  Cost me a quid. What i was trying to work out is if we have reached a volume peak of watches being discovered hidden in the back of drawers.  Those watches that were hung onto until they entered the hands of the non sentimental generation.
    • Even for myself who only started getting into watch repair/servicing during COVID I have seen a huge jump in watch prices - we have a 404 channel on this forum. When I started you could relatively easily find a watch on eBay to restore and put onto the channel, however this is now almost impossible and the only feasible solution is to buy a job lot with an average price <4.04. Even watches sold for parts/spares are 3 or four times the price of only a few years ago. Why - Either Demand must have increased in order to push up the price, or supply is reduced. I think it is a little of both, I think that most watches in the UK/US may have been picked over, which agrees with most of what @Neverenoughwatches says so supply of all kinds of vintage watches, including tat is dwindling. As a double whammy I think that more people are wanting watches, either to work on, or as a way to differentiate themselves from the Apple Watch and FitBit crowd. The upshot is that half decent watches that require restoration are now $500 instead of $100 and cheaper watches (Seiko 5 etc) are now $50 instead of $10, and even Mumbai Specials and garbage are now pushing $50 each. When - how long will this last, I think that most of the people who are returning to mechanical watches are those that have previously experienced life without them and want to return to something with a bit of personality that doesn't buzz every 10 seconds on your wrist and tell you how many steps you have done today. i.e. the 30-40+ generation. My son who is 17 has several mechanical watches but only wears one on a special occasion and is obviously only aware of them at all in part due to my hobby. I asked him the other day how many of his friends wear a watch and he told me that some use a smart watch but most just use their phones. So as I see it, demand will start to fall once the sub-thirty crowd start becoming the majority and/or the older amongst us stop buying watches and switch our attention to mobility scooters and trying to remember our bank password. Price - I think this is here to stay, even if demand does start to drop as the older generation becomes to decrepit and stops buying and the younger generation isn't interested in buying, supply will become progressively less as time goes on as more vintage watches become lost or broken beyond repair. I think the prices will plateau at some point as an equilibrium is reached as reduced demand is balanced with reduced supply, i.e. less and less people buying less and less watches. Sorry for the long ramble!
    • Hi. Use a PVA based glue, gorilla glue it dries transparent then do as advised by Old Hippy, smoothe down using very fine  0000 wire wool and either French polish or beeswax for a finish.
    • Hello and welcome to the forum.    Enjoy
