Seiko 7006A Strange Timegrapher Trace, Escape Wheel Issue?
Is there a tech sheet available for the 6601? I've only been able to find a parts list. If there isn't one, would there be one available that is close enough to follow along with?
I've used expanding foam for lots of things but i thinķ you got me on that one. -
By HectorLooi · Posted
This happened to me several years ago when I first got my barrel closing tool. In my eagerness to try out my new tool, I closed the cap without the arbor. I don't quite remember how I opened it. I might have used compressed air to pop the cap off. I sometimes use compressed air to open those "sealed" Seiko barrels. -
By LittleWatchShop · Posted
Welcome @Boggie46. I would encourage you to take a little time to learn the terminology of watch parts, e.g., "winder rod" is the "stem." It will help us to help you. I am curious as to how you removed the center seconds wheel. -
By nevenbekriev · Posted
Put the arbor in the barrel in the correct direction and look at the hook of the arbor. It will show You the direction of the spring.
