Smiths Sectric - hands dial
stoptheclock
Hi  I take it from the picture that the frame is a plastic moulding if so remove the dial/knob and inpect the bearing I suspect it will just be a hole with the shaft passing through it, If the shaft is also plastic  there is a possibility of wear . so a close look at that point before placing oil into non oil bearings.
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
