ETA Suit 7/21 Update
I read in Hodinkee this morning that ETA won the part of their antitrust suit to stop supplying movements outside the Swatch group. It said nothing about parts. I checked Cousins, and didn't see anything there either. Has anyone seen anything on the parts side of the ETA equation?
That is a different ligation and has nothing to do with parts. Unlike the Cousins one that has been (partly) narrated in details by the British material hose, this one as been conducted in the normal Swiss style, that is nobody except those with a direct interest knows anything about it.
BTW I think is Hodinkee is not more useful than to get swank styling suggestions. To learn more about the Swiss swatch industry sometime Europastar had insight articles.
OK. Wasn't sure. I don't especially care about who they sell movements to in terms of smaller companies making new watches. We need more Sellitas and the like.
Super agree. Came up in a news feed or I wouldn't have seen it (methinks Google has caught onto my interest in watches). The watch universe is divided into two camps: fashion/bling and mechanical object. The Venn diagram has a small (and probably a little blurry) intersection. The reason I spend my time here rather than other forums is because the focus is almost exclusively in the one camp with almost none of the pretenses of the other.
    • I just picked up this Mondaine quartz watch on tradera.com for £11. It's a non-runner so I will replace the Ronda movement (£10.95 at Cousins), polish the case, replace the case-back gasket, and replace the mineral crystal. Now, the problem is finding a suitable crystal. The original crystal is slightly domed (2.4mm thick dome), measures 36.4mm in diameter, and is 1.3mm thick at the edge. The closest I can get on CousinsUK is 36.5mm in diameter, 3.1mm thick dome, and 1.5mm thick at the edge. I think the replacement crystal would look OK, but the problem is finding a suitable glass gasket. The case diameter for the glass gasket is 36.9mm and the closest glass gasket I can find on CousinsUK is either 36.8x36.0mm or 37.0x36.2mm. I guess one of those glass gaskets could work but as you can see there's no way the 36.5mm domed crystal would fit the inner diameters of those glass gaskets. I guess I will have to give up on a domed crystal, no? So, the backup plan is to use a (1.5mm) thick flat mineral crystal as the diameters come in increments of 0.1mm. But, what glass gasket would be the better option? The one with an outer diameter of 36.8 (0.1mm too small) or the one with an outer diameter of 37.0mm (0.1mm too large). Again the case diameter for the glass gasket is 36.9mm. I believe I read or heard that the crystal diameter should be 0.1mm wider than the inner diameter of the glass gasket. Is that correct? I'm sorry for all the numbers. I've tried to make it as clear as I could. So, I'd appreciate your thoughts on this. BTW, measuring and sourcing crystals and gaskets is extremely time-consuming! 😓
    • Lots to choose from... Just sayin'.
    • New one on me too.  Is that corrosion on the crown wheel?  Let us know how you get on.
    • Case in point, I just scored a lot of 4 Timex mechanical watches for $15.50 which puts the individual watches at $3.88 each, or £3.09 (or €3.59, ¥28.08 (CH), ¥607 (JP), ₹324 ... or 0.00006 Bitcoin ) 😉
