valjoux 7730 cam screw hole to wide
hi chaps I have got on my bench a valjoux 7730 moment with chronograph issues. so I opened the case back and the cam screw used to adjust the pitch of the cogs fell out. I put the cam screw back in its hole but it should friction fit into place but unfortunately it fits in loosely hench why it fell out. any advice on how it close the hole up enough so it will hold in place again. I have mark in the image which one is the issue
You need to punch the hole with a convex punch about twice the hole diameter to close it. But you need to disassemble the watch to support the other side properly with a stump in the staking tool.
If it's your own watch and you don't mind a bit of a hack job you can slide a piece of hair in the hole. This is utterly unprofessional but might get you enough friction so it's functional.
That excentric setting screw (ES-2) is sitting on the barrel bridge if my memory don´t fail me.
It regulates the distance of the intermediary wheel teeths, normaly one leaves these alone if one isn't very used to work with chronographs.
Since they are friction fitted one really dont have many options to work with when the hole has become too wide.
One is to fill the whole with new material, silver soldering, and drill a new hole.
Next would be to buy a new barrel bridge and replace it.
Last choice would be using a punch to close the whole.
Neither of the three options should be done by a total novice. I think the Venus 188 might have a fitting bridge too.
(I see nickrelsilver already answered, I write just too slow ;) )
thanks for the quick response. this is my watch but I aim to get it back to a a professional condition I can source a new barrel bridge from cousins but not sure if the finish will be the same or if it comes prefixed with jewels, as cousins don't have an image on there site. anyone able to confirm or will I need to ring them in the week?
Closing the hole will work fine, really no need for more than that. The is really no force on the eccentric, it is just a positioner.
We were taught in school to poke the tapered end of an eccentric into beeswax before installing, and it works well for a smooth action and to keep the eccentric from galling with the bridge.
    • Newbie here too, but I’ve done a bit of reading around this subject. Looks like a Breguet overcoil. You’re right about A and B - A is just a minor tweak - but most damage is between B and the stud.    Pivots can be unbent, but there’s a high risk of breaking it off. Take care, and probably see how it runs before trying.    That’s really dirty. I’ve never found IPA to loosen Shellac. If you’re worried, put it in soapy water in the ultrasonic and then dip it in IPA as a quick rinse to displace the water and prevent rusting.    As for the stud - does it wedge in the angle and the screw holds it there?
    • No, it is browser dependent - your browser may have a spell checker you can switch on in settings. A quick search on Google may help you if you don't use Chrome: https://support.google.com/chrome/answer/12027911?hl=en-GB
    • Good to know, I'll move that to the bottom of the list
    • What you can do is type it in say Microsoft Word use the spell check in that then cut and paste it here.
    • Thank you for your reply, Curare.  You offer me hope ! Yes, my experience is that crystals with a tension ring require a very heavy screw down on the crystal lift - I’ve cracked a couple.  I think I’ll use a press to install the new crystal and keep my fingers and toes crossed that I don’t mash the underlying dial and movement. Waggy - there’s no bezel on this particular omega case and the movement loads from the front (there’s a spit stem), so the only option is to directly fit the crystal into the case with the movement in place.  And what happened to you could so easily happen to me!  I have woken in my sleep, heart racing,  seeing the fragments of smashed crystal gouging the dial and mangling the hands! I’m hoping someone who has worked on an Omega Dynamic might have some direct experience and will let me know how they managed the surgery. Thanks to all. Cheers, John   Oldhippy - thanks for your comment.  So, you’d just go ahead and place the crystal using a press, movement in situ, in the case?  OK - that’s what I’ll do.   Cheers, John
