valjoux 7730 cam screw hole to wide
hi chaps I have got on my bench a valjoux 7730 moment with chronograph issues. so I opened the case back and the cam screw used to adjust the pitch of the cogs fell out. I put the cam screw back in its hole but it should friction fit into place but unfortunately it fits in loosely hench why it fell out. any advice on how it close the hole up enough so it will hold in place again. I have mark in the image which one is the issue
You need to punch the hole with a convex punch about twice the hole diameter to close it. But you need to disassemble the watch to support the other side properly with a stump in the staking tool.
If it's your own watch and you don't mind a bit of a hack job you can slide a piece of hair in the hole. This is utterly unprofessional but might get you enough friction so it's functional.
That excentric setting screw (ES-2) is sitting on the barrel bridge if my memory don´t fail me.
It regulates the distance of the intermediary wheel teeths, normaly one leaves these alone if one isn't very used to work with chronographs.
Since they are friction fitted one really dont have many options to work with when the hole has become too wide.
One is to fill the whole with new material, silver soldering, and drill a new hole.
Next would be to buy a new barrel bridge and replace it.
Last choice would be using a punch to close the whole.
Neither of the three options should be done by a total novice. I think the Venus 188 might have a fitting bridge too.
(I see nickrelsilver already answered, I write just too slow ;) )
thanks for the quick response. this is my watch but I aim to get it back to a a professional condition I can source a new barrel bridge from cousins but not sure if the finish will be the same or if it comes prefixed with jewels, as cousins don't have an image on there site. anyone able to confirm or will I need to ring them in the week?
Closing the hole will work fine, really no need for more than that. The is really no force on the eccentric, it is just a positioner.
We were taught in school to poke the tapered end of an eccentric into beeswax before installing, and it works well for a smooth action and to keep the eccentric from galling with the bridge.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
    • No thats straight out of the watch as i found it the balance wheel is almost as bad. I've never seen so much material removed.
