Hello,
As a 'Newbie' I'm browsing the net to discover technics , guidelines etc. on my new hobbie.
I found that document from US war department dating 1945 about : 'Ordnance maintenance for Wrist watches' ...as you'll notice it's also an introduction manual for vintage watches, and some american watch models
Looking at it, I thought to myself how lucky we're to have internet and online courses ...
P.S : name of the attachment, is the official document name in US army archives
TM 9-1575.pdf
  • Thanks 4
Please don't be put off, but the document you've attached is well know and has been posted here not less than 7 times, most prominent ones are below.
Be welcome here and if in doubt on anything just use the search box top right or "google site search" for multi-word searchers.
Seems to me there should be a library on this site... A single thread, maybe even a curated one if it's possible within the forum engine to keep editing windows open indefinitely, wherein all such literature is deposited and organized. Most of this stuff is copyright free, so it should be simply a matter of getting it compiled and organized.
I thought at one time there was a library of PDFs but it seems to have gone missing? My guess is that maybe Mark ran out of space. The only exception to that rule is every single time somebody attaches a PDF over and over and over again soon the message board gets overloaded with attachments be better to point to a single library somewhere.
More or less what I had in mind. I've seen the 7S26 service sheet posted at least a few dozen times, for instance. For it to be useful though, there must be curation. A random list of documents doesn't do anyone any good.
No point in even trying. Do you think that the next guy attempting to fix his Seiko 5 will search before asking? No he will not, better said, probably many do and we can;t know, but still some doesn't, and kindly are given the answer every time. BTW did you know that you can quickly include anything that you attached before? Just click "insert other media" and search for it.
The info is all out there already, starting with Cousins UK that does a tremendous job with this stuff. If even one hundred 1kb sheets get separately posted thousand of times that is not even a drop in the ocean of the Internet capacity. Just learn how to search, and if something really matters to you save a private copy or print it. And if you find that Cousins don't have it, send it to them.
Edited by jdm
GeoMontreal
This may be a redundant post of this manual, but it its the first time I've known of it's  existence. I won't have know to search for it.  Military manuals are of some of my favorite referance reading.
Thank you for posting it.
Nora
    • Hello, My name is David and I’m a vintage watch collector/ wanna be hobbyist watchmaker from France. I really want to progress into my watch repairing hobby. For now, I’m only having fun servicing my own watches and spare movements, simple small 3 hands from the 50s (Omega, eterna…) Learning step by step or at least trying to 🙂
    • More setbacks and successes...  After letting the watch run in (but before I fixed the BE) a chunk of the radium lume fell off one of the hands and pulverized leaving radioactive dust all over the dial 😞 ☢️ ☠️ So before I could continue further I decided I would remove the radium lume.  I have removed radium lume from hands before where it was already starting to flake away but this time I had to work out what I was going to do with debris on the dial.  I decided that getting everything under water and removing all the lume was probably the best way to go. So here is what I did... I put an essence jar I use for cleaning parts and filled it with water and put it into a big ziplock bag along with the tools I would need - a sharpened piece of pegwood and  a 0.80mm screwdriver  -  I put on a pair of nitrile gloves and a covid style mask and then opened the back of the watch. Now with the back off the watch I could do the rest inside the bag.  I removed the watch from the case and removed the hands from the dial (through the bag) and then undid the dial screws and removed the dial from the movement.  I then put the hands and the dial and the watch case into the water and removed the movement from the bag.  Carefully and slowly with one hand in the bag and one hand trying to poke and hold stuff through the bag I gently rubbed away the lume from the dial and hands with the pegwood. I then took the parts out of the water and removed the jar from the bag (leaving the parts still in the bag) - with the majority of the dangerous stuff now in the water I disposed of this (down the toilet) and gave the jar a good rinse in running water before refilling it and returning it to the bag where I gave all the parts another rinse in the new water.  I then took the parts and put the geiger counter over the top of them and looked at them carefully under UV light to see if there were any flakes still hanging on. I dried everything with some kitchen towel. Once I was finished will all that I remved the parts from then removed the gloves and put them in the bag with the paper towels and the pegwood and thew the bag in the household waste. Finally I gave the dial, hands and case another rinse in the sink under running water.  I didn't bother following up with a rinse in distilled water water because the water here is pretty clear of limescale etc and I find it doesn't mark! So here are the results of my weekends work! Timegrapher dial down (dial up is almost the same) The fixed shock setting New crystal - and lume removed from dial and hands
    • Hi and welcome! I'm new here too—greetings from Leicester, UK.
    • Image of the watch with new crystal. I am happy with how the watch has turned out, bought from Ebay for £12 as non runner, and managed to get a donor movement from ebay for around the same price, crystal was £14.24 from Cousins. The crown is quite worn but still easy enough to wind the watch, and the dial of the watch has a few scuffs and some dirt that wouldn't come off without me worrying about damaging the dial.
