Worth Restoring...another Seiko
jnash
More seiko im afraid, i have no knowledge of seikos but once again it looks like a cool chrono so seeing if its worth the punt or be cheaper to buy it working ! So impressed with the help I thought I'd go again
Thanks in advance
Agree with Geo, unless you can obtain another dial and glass as the movement looks sound.
The pushers get stuck like that, usually, because the o-rings go hard and brittle. Be careful when you take out the movement ring though as the pusher springs can potentially fly away and go missing :)
I love these Seiko chrono's -
I agree with the previous posts if you could get replacement dial & hands it would be a great watch. What Seiko,s I have worked on they are easy ish to work on and run great.  Might be worth adding it to your wish list on eBay so you don,t miss one when one is listed.
This what it should look like which is a great looking watch
Edited by clockboy
Hi Jnash,
Looks to me that watch sufferred a crystal damage and a lot of carnage to the dial and hands, possibly center pinion and wheel..not too clear.
Movement looks clean.. It is common to find the auto weight bearing worn resulting in damage to the autowind plate but yours seems good.
I would imagine this watch suffered the damage when it was fairly new and got put away so you may have a good movement (see remark on the center pinion/wheels)....but...... I cant figure out the little holes in the dial.. it could be someone was already in there and you may have a mongrel.
I would proceed to tear the movement down, inspect as you go and if its all good then source the parts needed to fix it up
Anil
all sounds correct to me, holes in the dial are for a sub bezel.  i can imagine along with the hands and dial i would need a seconds, cannon aswell as its locked up.
May keep it for a rainy day..
Thanks
One of the all time classics and better than money in the bank.
all depends if im going to spend more than what its worth.. which im still unsure of, ive been really surprised with seikos for what they have gone for!
based on the case model , this is how it should look , quite nice actually (pic stolen from the site in the watermark)
not the inne bezel (showing markers) layer on the dial
Edited by jnash
    • The small pinion that is on wheel 3 is a normal gear pinion. Did clockmakers mix the two types of pinion in the one movement?
    • No real question here, I managed to clean and reinstall this straight. But I just thought I would share this silly design for a balance cap jewel on an old Junghans pocket watch caliber J32. The screw is in the center, the jewel eccentric; the opposite design from every other cap jewel I have ever seen. But it has no steady pins beneath so tightening the screw means the cap jewel wants to rotate away from the hole jewel. Without an automatic oiler, this took about 6 tries to oil and screw down the cap without spinning it away. A tiny bit of Rodico didn't really help. Happily they don't make them like this anymore.
    • Thanks for your most appreciated assessment with this. I will purchase a new movement.
    • Sorry I am confused by step 4. Which screw? There is the balance cock screw. I don’t think that is what you are talking about. The only other screw I see is on the side of the swan neck regulator. I do t think that is the one you are talking about either Well I managed to make it worse again but I could take pictures.  I had put the balance cock partially in place with one locator pin in. I wanted to remove it and I know I should use my screwdriver in the slot to move it off the pin but I didn’t l pulled wit my tweezers and it stuck then gave suddenly and was thrown a few inches away and of course the hairspring got tangled (a coil was above the cock) and untangling it from the cock deformed it.    I am going to try to put it back in shape and I will likely post more pictures after shortly. I’ll wait for feedback before reattaching it to the cock I am sorry I think I’ll give up. I was trying to remove the tangle. I had previously succeeded but now I just made more of a mess with this new tangle.  Lf you see my spring it is now just a knot.  Let’s keep a positive attitude. The movement was already broken. It was working but couldn’t be used. So what if it can’t run anymore… I went on and reinstalled the mainspring in the barrel by hand and managed to put the arbor back in.  Now I need to close the thing!
