Hairspring rats nest
I'm a great believer in learning from our mistakes but when this happened to me my heart sank.
5x2IV23djWBiJthxQbSx2AJJHgbqgB8dDalM0pyK_k-Wukp0r_ji2KfhLIypO6EIAvIWni8R89VKj6B6by8xz5ydOIDSejiUWkiiN148QCJ-b996RvOtqLwdMX_L_feTNQTP2fi0MCn08eajPQY7CR-tYw8qMHF1wddHD5XEMrg_yh_Pi20bbTbZne_5nF0mXhK_TvBxO8uDICQHLXda_SwcvJeoQvcod7k9E2XNFcGhG2xA1iLG-8DUJo7j8xr-tnyLXAPn9tdwr_DG2LaGqwxnbQjAYa5BdL7tn9h09Y-gNf0Jf4AtqaNA4G1QPBkHGBg43RZYeRPKUn-xtvrj-HTamLwK7PjT9U3tnbeGRuyFovvPYKx_zRlI4uKO6XbQlDedl619DO3UvwwXOF6gYrGPkGM-K2bdr8cDNI0b2Ezuli219uWP2ipPTNxe-XAlAXAgGoPvPZPZB_aBT6ApOmvNGz7uixCXutskD9IJNo0ByUdJzG6Nd0lQXiSD53udLlpNZ1RjHsESMpechmr3obK5Tmjcgh2ug3LqJHhar8hTYz1kWscfW5OHEBnEhG0ZdTB1DysoWEcV2f-RqFbUDyfuD2Q8Uq5YL8hLpeFZIwai6HLewUomGA5egQOCBoCQSMnzi-hw8eTBZVSLSD0QQH8d804n_YyX8ezsxhXuOWXEjrGd0xVT2lgd=w994-h1129-no?authuser=0
It's from an ETA 2452 so about £20 for a replacement.  It's not going to break the bank but I'll have a go at fixing this first.  I've searched the forums for fixing techniques so have some good ideas on how to proceed.
"The difference between a master and a student is that the master has failed more times than the student has tried".
First thing to do is to unpin that hairspring off of stud.( most important).
(Your search show should a similair advice I gave, OP didn't listen,   spent ages like this:pulling-hair-out:and ended up buying a new HS. )
To unpin I insert the stud back in the stud carrier even instal the cock, then unpin.
Next remove the HS and  put it on a white sheet of paper. No tac is needed.
Run an oiler through the coil, start form collet outwards,  to untangle any circle stuck under another, each time all the way to the end of HS, then you will see a much less tangled coil that is not hopeless at all.
Good luck.
Good job. :Bravo:   :geek:
Hairspring end got out of where ever it was tangled, easily didn't it? Imagine or try doing this with the stud attached.:pulling-hair-out:
Where it still can use more sorting out is easier to identify from the picture, Picture of a new hairspring makes a good model.
I would rest for a while, let your mind come back to this naturally, before your second attack,  one or two more attempts and you are very likely to have a near perfect coil.
Sort out as if you are sculpturing.
Good luck.
To insert the pin back , I put the stud back in its holder tighten screw, put balance&cock back on the mainplate, run the hairspring through the studs hole, put a bit of grease or thick oil on falt side of a screwdriver( not Rodico),  pick up the pin with it( pin stick to the grease)  and get the pin to sit perpendicular to  screwdriver, ready to aim for stud hole and push the pin home.
Some grease gets on the pin, rinse it off in lighter fluid.
I easily sharpen the tip of the pin if neccessary.
Yeah, that pin is quite the pinger.  Got it in last night and now the watch works, just.  More adjustment of the hairspring is needed.  Thank you all for your wisdom, encouragement and compliments.
@Michael      With HS laid on a white sheet of paper, you obviuosly see the detail better in contrast, falt surface also shows you where the coil is not plus more advantages that a tac lacks.
Removal of the stud, is a must in my book.
    • Hi I got a Jaeger LeCoultre K911 movement, where one of the stems was broken. Part no. Should be 401.  Im based in Europe and tried Cousins but its discontinued there and cant find it on Google. Is there a way out to join the ends? Or an alternative movement to source parts from?
