New Member From Greece
vaguras
Hello  to all!!!!
My name is Evan (short for Evangelos my Greek name), I am a chemist specialised to the pharmaceuticals, currently unemployed, but I am looking to pursue my dream and become a reputable watch repairer-maker! I found out the brilliant videos of Mark on you tube some days ago and so here I am!
I have enrolled to the Distance Learning Course of the British Horological Institute and I am trying  to collect the proper tools for a  workshop as the course demands. I am here to learn and help others in things that I know already,  as it seems the magnificent world of watches and clocks is endless!!!
Evan
Hi Evan, and welcome to the forum! I hope your horological studies go well and that you will eventually realise your dream.
Greece is going through some interesting times at the moment - and I hope that you and your country pull through it all.
Regards,
Will
Hi Evan,
Welcome to the forum! I hope your new career pays off and I'm sure that along the way you will have a lot of fun! By the way, I would be interested in knowing the details of the Distance Learning Course of the British Horological Institute. It's requirements, options, etc. Keep in mind I'm from the other side of the pond and not able to travel at the moment. Thank you in advance,
Cheers,
Bob
Thank you guys for the pleasant welcome!!!
Bob, regarding the BHI distance learning course :
General introductory information here:
http://www.bhi.co.uk/education/distance-learning-course
I an currently enrolled to    The Diploma in Clock and Watch Servicing - Level 3 - Technician Grade:
http://www.bhi.co.uk/education/diploma-clock-and-watch-servicing-level-3-technician-grade/
This is the first year of an exciting 3 year course! At the above mentioned link page you can find all the details for the course, there are no prerequisites, there are basically two pathways clocks and watches that you have to choose (no mandatory really, but it is extremely difficult to go for both pathways, too much practice as you are advancing in the next years).
On the same page scrolling a little down you could find almost everything for the course including questions about overseas candidates just by opening the corresponding files. You can also download the introduction of the course and the first lesson of the first year (technician grade):
http://www.bhi.co.uk/sites/default/files/Web%20AFV%20DLC%20Tech%20Introduction%20-%20V2g%20-%20editing%20revision%203.1.pdf
http://www.bhi.co.uk/sites/default/files/Website%20%20AFV%20DLC%20Tech%20L1%20-%20V2b%20-%20editing%20revision%204.1.pdf
I hope that I gave you a first glance of the course.
Evan
Hello Evan, I'm new too and have received a warm welcome from all. I'm sure you'll enjoy yourself here as I have. Please post your everyday wear watch to my thread in the Lounge. Not much activity but I find it facinating what others wear for an everyday day watch.
BTW. is there a spell check on the site?
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it. Yes, I agree, that is the question, and my gut feeling tells me that is exactly the case. Epilame was created to have an adhesive trait and the oleophobic property is just a side effect.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down. Gravity isn't the only factor at play when oil is placed on pallet stones. The oil receives a lot of bashing that may push it out of position ? Thinking about it if the oil stays in position for 10 minutes enough time for the escape wheel to scrape off the epilame , then  a walled in lubrication has been achieved,  the epilame is no longer beneath the oil ( possibly mixed into the oil )
