Dear community,
Finally convinced my wife that my amateur skills are good enough to service her Rolex Air King 3130. The watch has 10 years and this is the first service.
When removing the oscillating weight i noted that it was quite stuck and there was rust in the pinion (photo attached after cleaning with rodico - there was more rust before).
In the Rolex oiling instructions they suggest HP1000 to lubrificate the pinion.
Apart from a good clean and HP1000, is there anything else i should be doing to avoid the rust to come back again?
Many thanks
If you would like to avoid rust in the watch you have to avoid water in the watch.. This means If you are are doing a overhaul you want to change all of the gaskets and do a water resistance test.  If you send the Rolex out for commercial servicing they always test the water resistance..
Then there's the other itsy-bitsy thing what is the recommended Time between  servicing?  Typically  and you see this in  watch collecting groups with automatic watches they have a potential of running a very long time until they stop.  They will run away past life of the gaskets and the lubrication in the watch.. Which leads to an unfortunate consequence of  a lot of times they basically disintegrate and very unhappy collectors  that the watchmakers greedy wanting so much money to service their watch  at least what's left of it.
This is one area where I think Rolex got the design wrong. If you google you will find how if not lubricated and serviced  this pinion not only can rust but can wear away and has to be replaced. Cousins sell them but replacing this pinion without distorting the rotor weight is a challenge.
Does anyone know why they rust? Hygroscopic oil or oil that has turned acidic? Usually only natural oils do that.
what we need is a service guideline by Rolex for the watch was manufactured. Not the current service guide because more likely they change their recommendations. So for instance we see above the recommending an HP oil could they have recommended D5 at one time? That would give you your organic components.
Then one of the issues with servicing watches if you've ever been to a lecture where they explain high cost of servicing a Rolex watch is a lot of the components are meant to be replaced. Which is also why those components are available. It's one of my concerns as they extend the service life where lubrication really can't necessarily last for 10 years the assumption from the factory may be that you will just replace all the faulty components.
So this means for us unless you want to be replacing stuff if you know it's a problem then maybe the next servicing should be five years from now.
When Rolex is serviced by Rolex they now change the hands for new and they replace any part that shows signs of wear also when returned it looks like a new watch. Hence the price. Independents can not compete with this as parts are not available but can offer a lower price.
  • Similar Content
    • So if anybody overrides what i say, listen to them haha. I'm not an expert but i've just been in this boat a dozen times as i used to mess up hairsprings bad, but the good part of that was that i got to learn how to fix them.  What made my life SO much easier was learning how to adjust the hairsprings with the balance installed on a disassembled mainplate, unless it's a very serious problem or on an inner coil you can't get to i would recommend trying this in part because the spring will mostly ALWAYS look flat when the balance wheel is not installed on the cock. Install the balance wheel back in the cock and the cock with the cap jewels in the mainplate, with it installed even the most imperceptible twist will be pretty obvious. Just make sure the balance jewels are also installed. In these movements, if 99% of the time any twist or problems gonna be around the terminal curve, twists often near the stud, especially if you've been removing their awfully designed studs from the balance cock. If there's a reliable way to install those things without introducing a minor twist to them i haven't found it. they're an awful design. INstall the balance on you mainplate WITH your capstones/chatones and look sideways across the balance under magnification. Look for the highest or lowest spot of the now not flat hairspring. 180 degrees from that high or low spot is where your twist will be. You have to be VERY careful with twists as the tiniest over or under twist brings it out of flat. If the area i have to untwist is near the stud i just use a pair of #5 tweezers or some very sharp fine curved tweezers and gently see which way i twist it corrects the twist, then i hold the very fine point of the tweezers on the hairspring and just gently squeeze and check it and see if it started to correct it, then i rinse and repeat. Tiny adjustments is what you want, don't close them all the way, and dont' introduce a flat spot in them. it's just a little nudge by closing the tweezers on it at an angle. .  If the twist is not near the stud, i grasp the hairspring with some very fine curved tweezers as gently as possible while still holding it then i do that same sorta tweezer squeeze with my #5's.
    • Has it got the logo on the crown. I think you're best option is going to be to remove the damaged stem and measure it. Edit Do you have the case reference number.
    • Movement is Omega 1012. I bought this from Cousins:
    • Welcome to the WRT forum.
    • To get the full diameter, I'd have to take it out of the case, which I won't be able to do until the screwdrivers arrive.  I doubt that it's much use to you, but the raised rim on the case, encircling what you see of the movement, has an outer diamter of 28 mm and an inner diameter of 24.8 mm. The case outer diameter is 32 mm.
