Help determining part name?
Hello, I am working on an AS 1320 (Bulova 10BRC, 9AS) automatic movement and have found it to be missing a part for which I cannot find a name. I have looked at the 10 BRC automatic assembly parts list and the parts list for the movement itself and still cannot locate it. Here is a photo with the missing part outlined in red.
It is a spring-like device that prevents the automatic assembly's third winding wheel from engaging the ratchet wheel when the mainspring is fully wound. If anyone could tell me the name of this part so I could order a few replacement parts, I'd really appreciate it!
25 minutes ago, oldhippy said:
Can you post the link to the parts list or up load the list please.
I rember the part name list.    haveing a hard time finding it !    i'll keep looking.     vin
Hello, I used the Bulova Self-Winding Watches booklet (pg 18) and the '52 Catalog of Interchangeable Parts (pg. 79) to attempt to identify as many parts as I could.
15 minutes ago, Walsey said:
I don't believe that is the part but thank you.
    • Welcome to the forum, enjoy. I have a varimatic that went  out of sequence because it’s hydronic oil ran very low. Must admit it’s still in my garage just know time to fix it. Purchased a cheap Indian Junta/ sonic Pearl as a stop gap a few years ago and it still performs perfectly so no incentive to fix the Varimatic.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Recently purchased a L&R Varimatic knowing that the piston does not fully rise in the cylinder. The likely cause is air in the system. The manual calls for using a bleeder cup, which is as rare as hen's teeth.Does anyone have any experience with this issue and if so, how did they resolve it?
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
