Hello, everyone
Please could someone help me with a basic question as I live on a remote Uk island with no watchmakers.
I am about to replace the ETA 955412 movement in my 1992Tagheuer 6000. (See picture)
I have removed the Tag stem from the old broken movement and before removing the (temporary stem ?) and inserting my tag stem into new ETA I wanted to ensure I have the stem in the correct position and if battery should be in.
I have read conflicting stem positions on line hence the question.
Thanks for reading any help would be appreciated.
Gary
Hi Gary at all times unless testing the movement leave the battery out, whilst manipulating the stem into position .  It will be best to use the stem provided with the module. some of the modules require you to put the stem into set position before removing as this keeps the clutch assembly and associated gears in place to enable an easy fit of the stem. Failure to do so causes the clutch to drop requiring re alignment before the new stem can be fitted. To do that you need to remove the calendar work to gain access to the keyless work.  I have attached the tech sheet which covers this movement for you.        good luck
ETA 955.102, 955.112, 955.122, 955.132, 955.402, 955.412, 955.422, 955.432.pdf
Thank you for answering . Please excuse my ignorance on this subject
Do mean it’s best to use the stem with the Plastic crown that came with the movement?
And please could you let me know what the ‘set’ position is ?
regards
In the event you need a time-sensitive answer, I'd guess that watchweasol did mean to use the stem that came with the replacement movement. Perhaps that is because it will not have wear on it that the old one will have. It probably won't matter much though, providing the watch it was in was winding and setting well before replacing it. If you use the new stem you will likely have to cut the stem a touch and fit the crown.
"Set" position means with the stem pulled out in the position to set the hands.
Good luck.
Personally, with a screw-down crown like that, I’d just re-use it as is. It may be thread-locked in place.
I always aim to keep them in the inner stem position when removing, but it’s not essential. Gently twist the stem when you insert the new one.
Thank you all for your response I appreciate your help
it looks like the stem position does seem to split opinions or may not be important.
i will be doing the switch later this week, so I’ll need some luck.
Anyone else willing to offer any advise, I’m all ears and will take onboard.
regards And thanks again
Gary
My best piece of advice for that movement is to use a screwdriver blade which is wider than the stud that you press to release the stem. This controls what depth you press it to.
If you wish to use the new stem (not necessary if the one you have is undamaged) you can unscrew the plastic crown and replace it with the TAG crown. However, the TAG crown may be more or less glued to the threads of the original stem so that could possibly pose a challenge. You would probably also have to shorten the new stem using a cutter tool like this and you would possibly need to file the sharp edges after the cut (a simple flat diamond file works well for this). It's a bit fiddly...
The battery should always be removed while working on the movement. Replace the battery (preferably with a new) just before replacing the case back.
There is no "correct position" except the square section of the stem must be fitted into the square hole of the sliding pinion (AKA clutch wheel) so while inserting the stem, apply a little pressure on the crown towards the center of the watch while gently rotating the crown a bit back and forth until it goes in (into the square hole of the sliding pinion which you can't see). Unlike when you remove the stem, you will not have to depress the setting lever button when you replace the stem. Just shove it in! You can see exactly how the stem fits into the winding stem here.
You might find my ETA 955.112 service walkthrough useful. I believe it is identical with the 955.412!?
Good luck!
Thank you all for your help and advice, couldn’t ask for more.
i will be attempting the re build later this week hopefully, I’ll post how I got on .
kind regards Gary
I’d just like to add that what WW says is very relevant to this forum. Opinions do differ sometimes, and it can be hard to know sometimes what is best based on other opinions alone. In reality, you have to let experience decide for you in the long term. It may also be that your practical “style” defines how you work.
Success !! with your  help and minimal tools, I managed to get my watch up and running again.
thank you all very much
i put new hands on that look a bit overly (old hands lume had fallen off ) with the new lume compared to the patina on the face. I could not for the life of me get the new second hand on, but original went on easy.
really happy at the mo, hope it all doesn’t fall apart .
cheers Gary
    • What you’re saying is that if the entire coil is lifted or tilted either up or down it is due to a slight twist in the spring? Usually next to the stud?  I’ve chased this before and in one instance the spring came out of the stud and I had to reinstall it and secure it in place.  Do you find that the angle (not twist) the spring leaves the stud not only affects how it centers in the regulator pins but also the coil spacing? This could be caused by a distortion in the spring as it grabs and release the pins. I find turning the stud counter clockwise opens the coils 180 degrees away from it. So do I adjust the stud in relation to the regulator pins or to the coil spacing?  I also find that unless I remove the balance from the cock I can’t see the slight distortions in the spring. In my picture the distorted spring looked fine when installed. Do you use Alex’s technique of sliding the regulator arm up and down the curve to find distortions or can you visually see them?
    • So if anybody overrides what i say, listen to them haha. I'm not an expert but i've just been in this boat a dozen times as i used to mess up hairsprings bad, but the good part of that was that i got to learn how to fix them.  What made my life SO much easier was learning how to adjust the hairsprings with the balance installed on a disassembled mainplate, unless it's a very serious problem or on an inner coil you can't get to i would recommend trying this in part because the spring will mostly ALWAYS look flat when the balance wheel is not installed on the cock. Install the balance wheel back in the cock and the cock with the cap jewels in the mainplate, with it installed even the most imperceptible twist will be pretty obvious. Just make sure the balance jewels are also installed. In these movements, if 99% of the time any twist or problems gonna be around the terminal curve, twists often near the stud, especially if you've been removing their awfully designed studs from the balance cock. If there's a reliable way to install those things without introducing a minor twist to them i haven't found it. they're an awful design. INstall the balance on you mainplate WITH your capstones/chatones and look sideways across the balance under magnification. Look for the highest or lowest spot of the now not flat hairspring. 180 degrees from that high or low spot is where your twist will be. You have to be VERY careful with twists as the tiniest over or under twist brings it out of flat. If the area i have to untwist is near the stud i just use a pair of #5 tweezers or some very sharp fine curved tweezers and gently see which way i twist it corrects the twist, then i hold the very fine point of the tweezers on the hairspring and just gently squeeze and check it and see if it started to correct it, then i rinse and repeat. Tiny adjustments is what you want, don't close them all the way, and dont' introduce a flat spot in them. it's just a little nudge by closing the tweezers on it at an angle. .  If the twist is not near the stud, i grasp the hairspring with some very fine curved tweezers as gently as possible while still holding it then i do that same sorta tweezer squeeze with my #5's.
    • Has it got the logo on the crown. I think you're best option is going to be to remove the damaged stem and measure it. Edit Do you have the case reference number.
    • Movement is Omega 1012. I bought this from Cousins:
    • Welcome to the WRT forum.
