Working on a Hamilton 992 with a dirty dial. A fine cleaning with Rodico followed by targeted removal of spots and blotches with a toothpick; and then a cleanup with Rodico and Ta Da.
852b50ca2bddd21baf4da6b54276cf33.jpg43e69ac00b8dfc654451c9f635fb0ca8.jpgf9c756ba0c960b12443ba4ac073929e2.jpg
And the movement was cleaned with Rodico as well. Being very careful not to touch the jewel holes. This PW has a swing of 540 Degrees.
  • Like 5
8 hours ago, spectre6000 said:
How does that work?
Total arc of swing from extreme clockwise point to extreme anti-clockwise point is double the amplitude. So a swing of 540 degrees is an amplitude of 270 degrees.
Was the yellow mitigated by only Rodico?
Nice job.
No. Used a toothpick to remove the yellow stuff!! Then cleaned up with Rodico.
Thanks Marc. I usually use my iPhone in slo-mo to observe the swing. I also bought eTimer for looking closely at the performance. Would it be possible for you to make a video on how to use eTimer for diagnosing watch problems. Their manual is not sufficient.
Wow.  That's not before and after--that's night and day!  What a difference.  Beautiful movement, BTW.  Great job!
Thank you very much. Need to lean in with that toothpick
4 hours ago, jdrichard said:
360 plus 180 :) Full swing. Amplitude is 1/2 that value
Right. Duh. I read it as amplitude. Don't usually see it stated in terms of full swing. Opposite of BPM and Hz. I think in Herz, but it's always stated in terms of BPM.
So, you scraped every square mm of the dial with a toothpick, and yellow schmutz came off? Interesting... Seems like that's a porcelain dial-only strategy.
I scraped those areas with significant blemishes or moisture bumps, but I did do the whole dial carefully with Rodico
  • 8 months later...
Thanks Marc. I have read this in one of my books:)
Impressive dial restore/cleanup.  Still scratching my head pondering your method.  I guess you literally scoured every mm^2 with a toothpick and then removed the residue with rodico.
I have done some minimal dial cleanup with finely sharpened pegwood.  Then used rodico.
    • HI everyone Some context: I'm "in love" with old Timex. As someone who has always liked watches, I knew Timex (my first watch and another project) but, in fact, the brand had never really caught my attention. By pure chance I bought, in a set of two others watches, a small m24 that was sold as not working (run and stop), which actually started working by setting the date by manually moving the hands (15 days). This coincidence made me interested in its history, its reputation, simplicity/complexity of the movements and also because some were made in Portugal back in 70’s and 80’s. A few days later I found this beautiful 1975 Viscount, m33 (very low price, almost offered) and this is where I need your help.  It is in very good condition and works well (-20s per day is not a problem for me), and although the day of the week changes correctly, the date is "stuck" on the 10th. I live in a small town that only has one watchmaker and when I purchased this watch (and having read about these movements) I thought that since it was something theoretically "simple" (probably not related to the movement), he would easily solve the problem. I couldn't be more wrong. It was as if I had proposed a pact with the devil. He refused and said he wouldn't touch the watch (although he had serviced several of my watches before - Seikos and old Swiss brands). He suggested I wear the watch like this or trash it. As I mentioned in my presentation to the forum, I have some experience in digital watches, but in manual watches I am a complete beginner. I know how to remove hands, crowns and little else. I've been doing my homework, reading the technical manual and watching a few videos on YouTube. I think I can get to the part of removing the dial without any major problems. I know that in the Date Frame there is a wheel that at the top has a tab that activates the Day Wheel and that at the bottom activates the Date Lever My aim is to try not to ruin anything and  get the date working again. The help I needed (I intend to post photos) is that what should I expect? What are the most common problems that cause this system to get stuck (in this case just the date).   PS -  My secondary objective is to buy a strap at a overpriced value from the watchmaker just to rub it in his face that I managed to get the watch working properly. PS2 - In the photos you can see that before midnight the day of the week is already changing but the day of the month has not changed.   Sorry about the english. Best Regards Vasco
    • What is it from and how did it become bent ? It should bend back - I would heat it whilst bending
    • Ha, same here. I just looked and I've lots of pictures of my cars, be hardly any of me - I have a face better suited for radio. I did find this from about 20+ years ago. I'm the young looking one at the back, under the front nozzle.
    • I have a 6564 with me what is take a same tropic 12 crystal,most likely have the same parameters for the bezel. Do you need the measurement for that?
