Another Citizen question!
Hi
I am not having any luck trying to find out about this.
Cousins turns up a blank when I input the calibre etc, as does Borel. I was hoping to find if a new crystal and gasket were available.  Also just checking, is the crystal held in by a screw down ring and are they usually very tight. I’ve not tried to loosen it yet but if that’s how they are held I will need to improvise some sort of tool.   The numbers on the caseback are 5518-S96567.
Many thanks for any suggestions.
Well thanks, that’s most helpful. I must be doing something wrong, I tried several times. Did you put the # sign in as they say or just  4-S96567?  I’ll try it myself later and see if I can do it.
Thanks again:thumbsu:
If you click the little info box next to Citizen it explains it some. From what I've found, citizen case references are always 4- something. The reference itself will be the part after the dash on the back of the case.
Hope that helps, I'm just going off what I've found, I don't know 100% haha.
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
