Croton automatic AS2066 auto wind mechanism
By Embezelled · Posted
Thank you! That's immensely helpful. I appreciate the trouble you've taken. The initial hiccup aside, I do hope to treat this watch with great care and respect. I've certainly learned one thing not to do, and also just the general need to start out very slowly and very carefully. -
166.128 is the case reference number and the Omega logo is on the crown. This is the watch.
By TimepieceTinkerer · Posted
Hi all, I recently bought a pre-owned Elma Super Elite watch parts cleaner. The baskets had some rust, which I cleaned about 90% without damaging them. But recently I’ve noticed more rust appearing. I have two questions: Could this rust affect watch parts during the cleaning process? If I replace the baskets with new original ones, is rust likely to return in the future? Any advice or experience would be much appreciated! Thanks! TT -
So it's what people call a Citizen C Mark and was the first centre second movement they produced in 1950. This lines up with the serial number which dates yours to March 1951.
Hello I'm trying to install the Hour Counting Wheel assembly in a Valjoux 7750. The issue I'm having is the Hour Hammer Wheel keeps fouling on the Hour Hammer and the Hour Hammer Counter Lock. I believe it's because the Hour Hammer Counter Wheel is pinned to the Calendar Bridge. The latter prevents me from installing the Hour Hammer Counter Wheel separate of the bridge and seeing how it interacts with the other Hour Hammer components. These are my questions: 1.) Should I take the pin off? The one holding the Hour Hammer Wheel to the Calendar Bridge? 2.) Can this pin be removed? 3.) Any tips for installing the whole assembly if I'm not meant to remove the pin? I've included pictures to better illustrate what I'm writing about. Thanks in advance for any help that can be provided.
