my watches
henryr
I'm not a watch collector but may become one. My Accutron 214 that I bought new in 1966 stopped working and after searching for repairers, I found it would cost about $300. So I started searching for good quality used watches and settled on Seiko and Longines. My first purchase was a Seiko Diver 200m 7n36-6A49 in near mint condition. I'm not a diver but it looked cool and was in great condition. After more than 1 month it is still accurate within +-1 second.
I then started reading about HAQ watches and bought a Longines Conquest VHP quartz L237.2 L1.613.9 probably made around 1993. It has not lost or gained one second after 3 weeks. This watch looks like it has never been worn and it came with two extra links, extra pins, original outer box, inner box, instruction booklet in 4 languages including English, the warranty card with fields blank, another small card in Japanese and the jewelry store business card in Japanese. All these items are also in mint condition. Pages of the manual look they were never turned. Even the clasp appears never to have been opened as it is very tight with no sign of wear.,
So Maybe I've caught the collector bug because I continue reading about watches and have joined about six watch forums.
henryr
henryr
I hate to tell you but you are a watch collector. Are you sure you dont want to spend the $300 on repairing you 1966?
The Accutron is in great cosmetic condition. With the naked eye the crystal is scratch free and face and hands look new. There are a very few light surface scratches on the back, sides, bezel and bow ties. From a foot away they hard to see. Any idea what it might be worth after repair?
Edited by henryr
Just checked ebay for sold Accutron 214 bowtie watches. Most sold for $85 to $185 and one sold for $300. I searched more accutron repair sites and $300 is typical, just for a cleaning and lube. If it needs any parts like coils, cost could easily be $500 or more and  that doesn't include any cosmetic work.  I'm going to sell  is as non-working.
Welcome to the club. Ebay might say one thing but your heart may say another. Im pretty bored here on lock down you should let me fix that watch of yours. I had an old luminox that the tritium tubes died on that I replaced. I also rebuilt an oris TT1 from scratch that was my baby. Took me a whole year to get that 7750 down but now ive rebuilt so many of them that I can pretty much do it with my eyes closed.
Sent from my SM-G950U using Tapatalk
Replace the movement... That's what I did on mine. I bought a working 218D movement on eBay for about $50. Relatively simple swap, though the 214 is a bit more rare and desirable, and expensive. You can find complete watches too and just pull the movement. It's a place to start for sure.
    • I often get an amp drop after i oil the stones with 9415, not sure what difference can be achieved with oiling the teeth.  I guess the oiling surface is very small on a tooth as opposed to on the stones a larger drop might have more drag as the teeth plow through it. I oil with a bristle from a brush now, strangely enough the last movement i oiled five escape teeth and the amp was much higher than i usually get , coincidence ?
    • Who'd have thought to look at the supposed compatible calibres ?  🤔 Frank did 😅
    • I recently helped my mentor to service 7 Seikos and he told me not to lubricate the pallets. His reason was from his experience from the advanced classes that he conducted, his students all ended up with worse amplitudes after oiling the pallets. I have to admit that I had the same problem when I oiled the exit jewel, like so many videos on YouTube show. I actually ended up with worse amplitude.  But now I oil the escapement by oiling the teeth of the escape wheel. I think Rolex used to train their technicians this way. I find that I get about 20° -40° increase in amplitude oiling the escapement this way. I've only started playing with epilame recently. I got a bottle from a Chinese seller on AliExpress. It's supposed to be Episurf Neo but everything on the bottle is in Chinese. When the bottle arrived, half of it had evaporated or leaked. And when I brushed on a thin layer on a mirror, it dries rather slowly and even feels a bit tacky. When I did the oil spread test, like my experience with stearic acid, the treated and untreated surface of the mirror yielded similar results. The contact angle of the oil drop looked about the same for both the treated and untreated surface. When I epilamed an actual pallet fork, the escapement was so sluggish that I couldn't even get 180° amplitude. I dunno if I got conned by the seller but the results are just not convincing.
    • I usually just use 2 pair of pliers to remove the roller ( just kidding  🤔 )  I want one,I have an adjustable free standing one. But i really like the little bradux tool that nips under the roller with two tapered jaws that lift it off. You can get under a scope with it to see in detail how the job is going. There is some technique involved to stop you chopping the staff, doesn't particularly matter if the staff is already broken but it naffs up the tool's jaws if you crunch the staff, and the jaws need to be in good shape to prevent damaging the roller. But well worth a try if you've never used one and you can find one that hasn't been misused or buy a one new. The trick is to keep one of your fingers between the two arms to soften the squeeze, with a little practice its a handy little to. I will now prepare myself for an onslaught of negative feedback on it 🤣
    • With luck even possible to fit your 13 lin. movement at all 😀. Those numbers are from 5 1/4, 8 3/4 and 13‘‘‘ sizes, with very different balance wheels! Frank
