Rolly
Rolly
HI,I am From Canada,
                                         After 30 years, as a butcher I had to change my carrier, for medical reason, so I change for one of the oldest trade in the world,
I follow a course in Horology shcool, and than went on my way.   But this course was to work in a jewelry store to change batteries and straps and bracelets.
So I miss quiet a few things in repair manual movement, so I enroll in this very good course.
    • Back home...printing now.  Will report results
