Making Kundo Keninger & Obergfell clock works
Dick
I’m new here. I bought the anniversary clock and am trying to get it working. I observed the body of the clock the spring cable of the pendulum seem fine.
1. I tried to rewind the clock counterclockwise (not sure it is correct), the tension is so great and bounced back when releasing the key.
2. Not sure if the spring for the clock body works since I’ve never heard any tick tock.
That was a start, any advices?
This type of clock is the sort many clock repairers do not like to repair. The first thing I need to see is the suspension spring. That is the long thin wire at the back. I need to see the back plate and movement as well. Can you take good clear photos and post them.
Dick, as a new member we like new members to introduce themselves in the correct place in our friendly forum.
Thanks.
Hi Dick and welcome to the forum.  With 400 day/anniversary clocks there is no discernable  tick tock as on normal mechanical clocks, The mainspring is small but very powerful driving a clock such as these, The energy consumed by the clock when running is very small hence the name, It can run for 400days or be wound once a year (anniversary). The rotary pendulum hangs on a thin flat wire connected to the escapement fork which moves back and forth in tune with the pendulum releasing the escapement. These are simple to work on and a pain to set up and must be set dead level for them to work.  As mentioned we need pictures of the back plate to determine the model of the clock  Ok its a Kundo but there are different models of Kundo.      Cheers
I have serviced/fixed many.400 day/anniversary clocks over the years. They are a real challenge because everything has to be perfect for them to run and are expected to run for 400 days with a single wind. The one thing that must be absolutely correct is the suspension spring. It must be perfectly straight with no kinks an also be the correct strength. If the spring is touch too strong or weak and you will just run out of adjustment. I really recommend this book which is my bible with these clocks.
Horolovar 400-Day Clock Repair Guide
Terwilliger (Charles)
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the whole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
