One of the interesting problems that I wrestle with occasionally, when checking out watches for purchase or purchased, is the identification of movements. There are two aspects to this:
1. In many cases, the seller doesn't know the movement make and calibre and, although there might be a very good photo of the movement in the auction, he/she doesn't know the details.
2. If I take a punt on a watch - and, for me, the movement design and engineering is just as important as the dial, case, etc. - I'm reluctant to do any dismantling just to get under the balance staff to ascertain a calibre.
Ranfft is very useful as a movement database, but the sheer quantity of data in it means that it might take hours and hours of guesswork to locate a particular make and calibre.
So, my question is: is there a way of using the broad design of a movement - the shape of bridges and plates, for example - to identify (broadly) whether a movement might be FF or AS or ETA, etc.? Even a rough narrowing down of this sort might make Ranfft (which is not 100% complete either) a little easier to use?
A friend of mine - an amateur but skilled watch service man for over 40 years - has an old book of movement parts, in which a calibre can be identified by placing a setting lever exactly over a corresponding drawing in its pages. A great work of reference but, once again, not much help if you don't want to tamper with a perfectly good movement!
Aha - I hadn't spotted this one! The Ranfft home page is not particularly well laid out, so I must have missed this.
Thanks for the heads-up, Geo, I'll dip in and get cracking! :bow:
Just tried it out on a couple of incoming cheapies - I managed to identify one as an AS 1194 (Rodania), but the other, an Elco, is still a mystery.
But I'll keep plugging away!
Glad to be of assistance Will.
I found that a few months ago when I was trying to identify a movement in a Sully triple date moophase watch that I bought. It's a great search facility, but I still didn't manage to identify the movement. Hopefully all will be revealed when I haul it apart!
Will your friend is probably using  BESTFIT books which I use now & then. I have volumes 1 & 2 (see pics) They come up now & then on fleebay. With the older vintage watches you like these books would be invaluable
Edited by clockboy
The bestfit books are excellent. They provide more information than just movement ID as well. They are a very good resource to have especially for vintage calibers.
BestFriend indeed, i have a backup aswell!
As a follow on to the BESTFIT books does anyone have the definitive guide on how to use them.
I get by, but I suspect there is a lot more information in these books than I realise.
Hi guys,
Any particular way to search for those books on ebay? ISBN number, edition, markings or other? I get different books and parts...some are really expensive!
Thanks in advance, Cheers,
Bob
HI GUYS, I USE THESE VOLUMES FOR IDENTIFICATION THEY DONT SOLVE ALL PROBS BUT I FIND THEM VERY USEFUL, I HAVE THEM ON PDF SOMEWHERE SO IF ANYONE WANTS A COPY PM ME, ALTHOUGH THE BESFIT CATS DO COME UP FOR SALE THEY ARE EXPENSIVE SO IF ANYONE HAS ONE ON PDF I WOULD LIKE ONEpost-618-0-71495300-1422382322_thumb.jpgpost-618-0-77243300-1422382325_thumb.jpgpost-618-0-42494400-1422382329_thumb.jpg
Hi guys,
Bob
Search for "Bestfit watch book" should return a result. They are getting a bit rare these days.
Heres one: http://www.ebay.com/itm/BESTFIT-111A-Encyclopedia-of-Watch-Parts-/371239782208?pt=LH_DefaultDomain_0&hash=item566f9d8740
Best to find both volumes if you can though.
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
