Remove 1960 Timex 100 Crown & Stem
I have a Timex 100 watch with a 1960 date code on rear cover.
The second hand has come off. I do not know how to remove
Crown & Stem. Not sure how to add picture to this post.
This is my 7th grade watch in 1960, watch still runs and never
was in for repair.
Thanks
Ted
The 100 would have a model 22 movement inside and not a 24.
and how about that -
"This is my 7th grade watch in 1960, watch still runs and never
was in for repair."  a 60 year old Timex never repaired and still running!  So much for the claim that these were throw away watches.
Just tooting the Timex horn!
24 minutes ago, lakeradio6 said:
now, It looks like second hand was a friction fit to movement. I will try to re attach
so you pulled the second hand off and you noticed a thin metal shaft attached to it rigth?
This is very common issue and by coincidence I just had the same issue with this 1959 Darwin I worked on.  I have them in stock so just replaces it and the gave the movement a good cleaning and fresh lube.  Running great now.
5 hours ago, JerseyMo said:
correction to model name - not Darwin -but rather this is a Bayonet.  The Bayonet would have a wrap around crystal where the Darwin does not. Also the Darwin is front loading.
hello, so I got stem out. The second hand has a small hole the same
dia. of second hand post on movement. It fits on post loose, and
just falls of. Then I noticed the hour hand is loose and I can move
it with very low force. As of yet I have not been able I reinstall stem.
Will work of some more. I see there is a flat section on stem,
does stem need I be turned A set way when insted ?
Thanks
lakeradio6
place the second had on flat metal surface. than with a flat tipped tool such as a puch, peen the hole down.  this will help to reshape the hole.
insert the stem back in and you should see the brass spring lift up some. than you have to push the set lever in on the right side where the spring is. this engages the lever into the notch of the stem and that brass spring should now lay flat. got it?  takes like 5 seconds to this. typing instructions takes longer.
I will try both, do not know where's " set lever".
Thanks
I am sorry about all this. I see the drawing of set lever but cannot
tell where it is in movement. The dial is still on movement. Looking
at movement rear I see no screw for set lever. Not clear what is
keeping stem  from going in place.
add a picture...
    • Thought I had to share this - last time I cleaned out a deep fat fryer there was less mess than this. Another pin pallet movement. Unsurprisingly dunking it in Castrol GTX didn't fix the broken mainspring which is the only issue I've found.    Any tips for the dial? Also covered in oil.
    • Hi Nev . No i didn't try this balance in the movement as it didn't run and the deformed staff broke when i removed the roller. Problem is what i think is the correct staff for this movement, the hub seat, roller and collet profiles are all too small for those parts of the assembly. The movement listed on Ranfft's site is correct my movement and the nos staffs i have match the ronda measurements. I can only assume that the wheel , roller and collet openings have all been broached to make them fit an oversized staff, both staff pivots had also been modified.
    • Yes, threw it on the demagnetizer before I cleaned it to be sure.  This picture doesn't show it well, but I can definitely see liquid where the turns meet up.
    • My newest 404 candidate, a late '60's / early '70's Waltham with a UTC 33 / Seiko 6601 17 jewel automatic movement. It needed a new crystal and I put on a strap from my Strap Graveyard. The timegrapher was a snow storm before servicing but it cleaned up nicely. I really like the funky font used for the hour markers.
    • Hi Rich, the main problem with the balance is if the roller is from this movement. Did Yoy try if the balance interacted correctly with the lever? You can use suitable (by size) balance/hairspring couple from You pile of balances, but the roller must be for this lever (original for the calibre). Not that making roller is impossible, but it is easier to have one.
