Hi friends.   Need a little help.  Im buying a used
IWC Big Pilot 5002.   Can anyone tell me how to spot a fake big pilot 5002.  Any help will do.  Thanks
Hi ygonz17,
Welcome aboard! I'm not very familiar with IWC although I own one. I hope some other forum member can shed a light into this one.
Cheers,
Bob
Well, if you don't know anything at all about the brand of watch, all I can advise is to look at as many examples of the Real Thing as possible - hi-res photos from manufacturers' and sales catalogues taken from all angles - and then compare them with what you're thinking of buying. Easier if you're buying face-to-face than from an online site - and, if you intend to spend real money (IWC are very expensive watches), keep away from eBay unless you're dealing with a known and trusted seller.
Coincidentally, following on from Jaycey's excellent posts about the Rolex, I was looking at IWC watches on a replica watch site this morning - out of curiosity. They're very good-looking replicas - Chinese movements in most of them - selling for something like $300 and, to the uninitiated, just like the real thing. The site is quite straightforward about the watches being replicas, and they describe the movements accurately - but lord knows what happens to them after they've been bought... :hair:
Fakes avoid like the plague. My brother purchased a fake Breitling  (€35) it worked for a month then stopped. When I opened it the oscillating weight turned not in a bearing but in a brass type metal bush that had worn.  As far as I was concerned it not possible to repair economically.
  • 1 year later...
 All things being equal, why did you select 5002?   When it comes to the expensive watches, you have to know your seller. In the past month I have bought for expensive watches from presumably trusted sellers. Two of the four were returned.   They claim  honest mistakes.
Thread is 20 months old, do not expect a reply. OP appears to be one one of these people that joins forum is desperation, and do not follow through.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
