Ok i finally did it, not the best job but def will pass my standards. The 60 is slightly off, the weld was a bit shabby but ok. I ended up using a tool for wood burning, its does not heat up as much as a solder iron. There is a tiny chip by the 50 that occurred when removing old sub dial, kinda pisses me off the most because without that would have been dam near perfect.
Edited by saswatch88
What do you use to solder the foot to the dial ?
Is it possible to use one of those common soldering irons that are used on circuit?
I didn’t have to solder on the feet, that i could never do
Sorry, I meant the sub-dial. What is the substance that you add when soldering ? (not very knowledgeable on this topic but I want to know more)
i just moved the solder that was already there over in order to release the sub-dial then installed new one then pushed the solder back over.
