Hand pulling / re-setting.
vext01
Hi everyone,
This evening I put a new movement into a vostok watch. I also bought new hands, as the lume was crumbing on  the minute hand.
I thought it'd be a simple job (compared to a full movement service), but it turned out to be much more effort than expected. Why? The hands. I had a really hard time getting them on and aligned. I tried so many times that I "wore out" the new hour hand -- it eventually failed to grip the pinion. (I ended up using the old hour hand and new minute and second hands. It's no big deal as the watch is pretty beat up anyway. I wanted to keep it though because it has "character"). I also sadly scratched the dial a little, although you can't really tell. I guess it's all a part of the learning experience.
I have some questions for next time:
  • Do you folks sharpen your hand pullers? The ones I have seem too large to get properly under the hands. I wonder if I am supposed to sharpen them. (they are cheap anchor branded ones).
  • Are there any tricks for getting the hands on so the date flips at exactly midnight? I just spun the hands until the date clicked over, then locked the crown in before putting the hands on. Even then I had to try many times, as I was often off by a few minutes.
  • I've just noticed that I have not put the second hand on right :huh: If I rotate the watch around it freely spins. Doh. I'll have to research what I did wrong there.
  • Any other tips for a beginner?
Thanks!
EDIT:
About the second hand. In this video the chap explains that there is a spring that needs to be supported while pushing the second hand on:
Sadly he doesn't show this procedure.
Edited by vext01
about the second hand.
2 hours ago, vext01 said:
Hi everyone,
Thanks!
EDIT:
1. You can sharpen the pullers from the inside not the outside. Getting quality pullers like Bergeron presto makes a big difference, there are sets for each use. No 1 is best for generic work then there is No 6 which is best for thinner hands and sweep seconds because of flat thinner blades. Its best to have both.
2. Sets hands at exactly 12 o’clock before removal, and reset the hands at 12 o’clock
3. You have to support the bottom of the sweep second pinion while pressing on the second hand, if there is a spring holding it in you need to move it out of the way before supporting it. If there is a jeweled bridge for the sweep pinion you need to support the jewel, find a movement holder with adjustable pinion support that fits the size of your movement. Might be tricky with Russian movements since i had similar issues for vintage American movements. Most are made for Swiss so you can figure out the ligne size of the movement by measuring in mm and converting to ligne. Which calculators can be found all over the net. There are ways to cheat here if you dont wanna go this far but they are not recommended. When in a pinch i will rest the movement upside down on a staking block with hole just big enough for the jewel/pivot. If you dont have a block a hard but semi soft surface will work, like a bench Mat or cutting mat.
Tips: buy a hand setting press for $15 on eBay. They nylon tips aren’t the best when they wear out you can buy more, this device makes it easier to put the heads on steady and straight esp if you are new and not use to doing it by hand. I use Bergeron hand setters but when i started this device was a godsend.
Edited by saswatch88
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the hole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
