Happy new year to everyone. I know that these Rego/Cimier watches are cheap, but I really do like their style. This watch is running good and accurately but someone fitted an incorrect replacement crystal on this watch. The second hand is running into the crystal and stalling the movement.  My question is, has anyone here replaced a crystal on one of these watches and if so, do you have the specific dimensions of that crystal? This watch uses the lapanouse pin pallet  movement if that helps. Thank you for your time.
Well then remove crystal and get a domed crystal for replacement. GS Lo-Dome or Hi-Dome. Measure case with digital caliper and add .2mm to it. You can install crystal with brass Jaw type crystal remover.
Remove the incorrect crystal measure its circumference & replace it with a domed version.
PS Although it is a pin lever movement I agree it is a nice looking watch.
