Flebay Seiko 5
purchased this lastnight after being unable to sleep at what i thought was a reasonable price £10.50 posted :) but looking at pictures someones butchered a normal leather strap to fit any ideas on replacing with something more suitable on arival? any info on the watch would be good aswell thinking i might have a go at servicing it at some point to (good starting point i think?) regards Ben
Hi omega,
I can't read the number on the dial but it seems a regular 7S26 movement. If the back is original it may have other numbers separated from this one by a hyphen. That will be your case number and a starting point to order/locate a suitable bracelet.
An alternative is measuring the distance "between lugs" and total width of the band and try to adapt either a metal one or modify a leather one. I've done it using a dremel tool on a "shark mesh metal band". I suspect those bands are hard to find.
Cheers,
Bob
Hi mark i came across that one on my search. think its similar but my watch requires a 24mm strap so description says anyways. and i think that ones only 20mm at the shoulders. suppose i'll have to wait and see when it comes hopfully not to long but does say upto 28 days shipping. have came across these http://ebay.to/1tYbo1Cone on far right looks like the right fitment emailed seller for measurments.
Hi Roger yeah i'm a fan of there looks also but just going to be planning on using it for work and will get bashed from time to time so used was the way to go. yours is fantastic though! regards Ben
Have searched that but havent came up with anything. can see this proving to be a pain in the a*rse! Regards Ben
I bought this for another watch.
10mm centre link.
Was being sold for a 22mm curved end watch.
1mm narrower on the shoulder shouldn't stand out that much?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
