I decided to attack a slipping mainspring issue on a 19 Jewel Elgin Railroad grade Pocket Watch. Here is the movement.99d191719dc48e795a463e9d54b92c7e.jpg
I had to get the barrel out and have a look and much to my surprise to mainspring had a leaf riveted to it similar to automatic watch mainsprings.2ed0a5867d7c0b7d6e199b4787cad578.jpg
There was a small tab on one side of the mainspring and an accompanying thin slot on the barrel. What I did was file the tab so it was more like a hook and would better catch the barrel slot; and not slip. I also greased the wall of the barrel with automatic mainspring grease, to give it a bit of grab if the hook were to slip.92ce329f490e89b44b68f7ef810be1dc.jpg
The result was very successful.
Here is the YouTube video I made of the operation.
Then I noticed the the screw I had selected as a replacement screw (one of three) holding down the center wheel jewel setting did not looked domed like the other two. So, out came the lathe for some very detailed work to fix the look of the screw. AND AGAIN, I made another YouTube video.
I think I like making videos:)
That was a good part of my day yesterday and now this beautiful Elgin is completed and keeping perfect timec8ffa8a6c328765653a824c26ee57013.jpg
in the past, there must have been some "after market main springs"  sold.  my railroad elgin has a main spring that is quite stiff.one watchmaker said it was a "lifetime main spring".   i plan to instal a standard spring.  vin
Elgin had one of the first (maybe first) "unbreakable" mainspring alloys, Elgiloy, and it was excellent. They developed it shortly after WW2.
This mainspring is a monster, definitely not the same material at the other vintage watches I have worked on.
    Yes;  i don't know the proper name of this spring OR who made  AND who installed it,  but when i took it out of spring barrel it un coiled violently  --- it was very dificult to get it back into the barrel..     i see jdrichard has figured it out.    vin
    also,  there was a shim under the balance cock.   SO;  it must have been a half ass job by  an amature.   vin
I did and the watch works perfectly now, with a 540 deg swing on the balance...crazy.
Don’t think there was a shim??
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
