Replacing Glass In Rolex 1675
Well then there are these:
https://www.cousinsuk.com/product/watch-bezel-fitting-die-set?code=B30545
Or you could seek out a local engineering company that might be willing to cut one down for you in their lathe, or any local clock workshop should have one, they may help you.
These are pretty good value Mark, thanks for the heads up! :-)
Maybe I can find someone with a lathe. Which diameter die did you modify?
I modified four different sizes as this is for other Rolex models too then I painted a green band around them so I could easily identify them in the box of dies I have. If you measure the outside diameter of the glass you are fitting and choose the die accordingly you will be fine. And, naturally, the depth needs to be at least the height of the glass.
Thank you guys, here's the odissey I went through to get this job done: The watch came originally with a plain glass, (no magnifier) so I tried to track down a correct one with the magnifier (ref 714AWD) I first got one on ebay for 43$ shipped. After some time I decided to take the watch to a watchmaker to install it, probably the glass was ruined by using the kind of press in the picture and applying too much pressure, at first it was even inserted unevenly, it was taller on one side. Anyway the glass developed some kind of tiny cracks inside. I tried to polish it but it was not good anymore.
So I tracked down a new glass and this time I found one on ebay for 19,99$, took it to another watchmaker, this guy managed to crack the new one and reinsert the old one, he also told me that the one that cracked was the old one, that he cracked it while removing, infact he cracked the new one, I am sure as the old one had a tiny sign on the inside and it was still there. Then I got fed up about these people, tracked a new one which this time I paid 33,95$, bought some tools and replaced it by myself. I used a budget screw type press.
Hi chriz,
That is my first press, does the job but it is wobbly and not very even. All that said, it has been my workhorse for quite sometimes. Now I got better ones and I can tell it makes a lot of a difference...no more cracked crystals and better/faster performance.
I'm glad you were able to fix the watch. Good job!
Cheers,
Bob
    • Hi Richard,  I keep buying CAL.59 movements to practice on 🙂 Not started yet though, I'm gathering tools and building my confidence to start.
    • Problem solved. For some bizarre reason, the hook on the wall of this barrel is not properly centered vertically, but is oddly high on the wall, maybe 3/4 up the way up. When replacing the mainspring, this caused the outer coil to be displaced upwards as well such that it protrudes out of the barrel and caused the barrel lid to not sit quite flush to the barrel. Since this is a motor barrel, the lid is actually the first wheel and inner coil tube/hook all in one piece, with no “snap down” action that would have made the problem more immediately obvious. Maybe with an older mainspring the spring’s end hole was enlarged such that this wasn’t an issue, but hard to say how it ever worked otherwise. Replacing the barrel with one from a different model 1900 where the hook was properly vertically centered allowed the lid to sit flush without mainspring interference and the friction problem went away. The bridge was far too thick to be bent (and isn’t), for those of you thinking that was the problem. Placing the removable arbor in the watch without the rest of the barrel proved that the proper end shake was actually there as long as the overall height of the assembled barrel was correct.
    • You are so true on a lot of what you have said. The main reason for changing the mainspring even if the old one is in good order is because it will take out your thinking that the mainspring is contributing to poor power output or fluctuations in amplitude. If a new spring is fitted that box can be crossed off as a potential source of a problem. Most customers are happy to pay the extra £20 for a new mainspring if they are already parting with a couple of hundred pounds for a service. A new spring is an investment for good running for the future.
    • According to Borel the 814 and 815 use the same escape wheel. It's kind of an oddball being so long.
