Hi everyone.
As some will know most quality hand setting press fit tools will have replacement tips available. I have a set of bergeon hand fitting tools that, one clumsy moment after another have had enough tips snap to render the set useless.
Id like to replace the tips but I cant even figure out how youre supposed to remove what remains of the old tips.
Even on ones with plenty of plastic to grip theyre in there far too tightly and im stumped.
Anyone have experience here?
Are you talking about the ones with plastic tips ? If the old ones are damaged you can probably use a pair of pliers to pull them out. Inserting the new ones should be easier.
Theyre super tight, trying to grip where there is still plastic left the plastic gives way/crumbles before the tip starts to pull out.
I dont think they have a thread but that actually might be worth trying. Thanks
Edited by Ishima
Hi everyone, so ive managed to fit the new tips now.
I had to be extremely rough in getting the old tips out, basically destroy them as much as possible and dig out what remained.
The new tips went in with reasonable friction so there was no issue there. Thanks for your help.
Edited by Ishima
