I can't for the life of me find servicing documentation or guides for this movement anywhere. Going with pure intuition I'm afraid is inadequate either as all the chronograph parts are completely obscured and I can't observe their operation. I know how everything goes back together but trying to figure out how all the parts interact while in operation aches my brain. The thing is couple orders magnitude more intricate and complex than a 7750. Can anyone help me out with all the lubrication points particularly with the chronograph parts and the clutches? Thanks a bunch.
Personally I very rarely look at lubrication charts or even movement drawings. Lubrication is a personal preference item. I use mainly the moebius HP series of oils with 9010 for the cap jewels. I have had no issues using his method.
I appreciate the resources saswatch88 but I wonder if anyone else has anymore. I have seen these before and would like to know if there's anything more thorough. clockboy I have used pure intuition with many movements. It's easy when you can see how everything works or simple enough to mentally visualize. But with mechanisms such as in the case a chronograph featuring column wheel, vertical clutch, AND flyback complication it is really difficult to figure out how it all works and intuit where to apply the lubrication, especially when almost all the relevant parts are completely obscured and make observing their operation impossible.
Edited by CaptCalvin
This document does give some more info on the function of some of the parts if you haven't seen it
https://sweep-hand.org/2017/03/09/citizen-8100a-8110a-chronograph-instruction-parts-booklet/
Did you spot that the pink document on this page has generic citizen chronograph oiling instructions near the end?
https://www.thewatchsite.com/14-user-manual-technical-manual-casing-guide-downloads/171138-1971-citizen-technical-information.html
If you search eBay for Citizen 8110 pdf, then you can buy a pdf of the servicing instructions... in French.
I agree with clock boy, just oil the chronograph exactly how you would oil any other chronograph. The videos i sent should show the functions as he is re-assembling the movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
