Alright so I'm having some problems figuring this out. The watch below came with all parts original, as far as I can tell. It needed a new gasket and since the glass was hard to find I polished it a bit and after servicing the movement assembled everything in place.
Unfortunately, when I pull the crown out, the movement inside moves a bit sideways (same when I push it in) and there seems to be a small (but visible) gap between the chapter ring and the case, hence, making the dial visible (it's worse when you add the glass because of the magnifying effect).
From looking online the glass seems the original one but I can't tell for sure. I am starting to wonder whether the watch had an acrylic crystal with a tension ring, originally, and maybe a gasket as well.
Do you think that if I installed a gasket and then an acrylic crystal with a tension ring, the tension ring would cover the gap but also stop the dial/movement from moving ? The movement itself has the original plastic spacer and also 2 metalic strips to hold it in place which are also original.
I've seen some online photos but I just can't figure out whether those have original glass/crystals or whether they have tension rings or not. Please help!
Let me understand. the movement didnt wiggle before you removed the crystal correct? if so when you took it apart did you see a gasket or a tension ring? It does look like the stype that would use a tension ring but Either way a tensing ring is not going to help with the movement wiggling nor would a gasket. it looks as if you didnt install the movement correctly or the movement spacer is seated right.
Most of the T-12 in these cushion cases have a multi sided screw-in bezel. Does yours have internal threads in the case?
It is possible to install the movement ring upside down, thereby upsetting the relationship of the dial, movement and case, there may be some witness marks left by the screws previously so its worth checking.
Also you could have a wrong or worn out movement ring. These Tissot usually have white a plastic one and sometimes the area where the case screws sit are worn. I have had to repair them by building them up with super glue and dressing them down with a file.
In these designs, the movement is fixed to the ring and the ring is what determines the relationship of the dial vs movement.
Anilv
@saswatch88 It did this before, as well.
@anilv This model does not have any kind of bezel. The spacer was installed correctly and it is not damaged. With the movement and spacer installed, I can actually use a tweezer and just slightly move the whole ensemble around (talking 0,1mm or so...). Takes a bit of force, though.
Not only does it slightly move when pushing/pulling the crown but also the gap between the case and chapter ring makes the dial visible just a tad and it looks out of place. I highly doubt that that is how these watches were made.
What I have noticed is that the crown has a gasket inside but it's not rubber but actually plastic (it seems to seal in the case pretty well but not sure how water resistant it is) and it sits very tight when inside the case tube. For example when I'm manually winding the watch (or turning the crown the other way to produce that well-known clicking sound) I can feel the crown very tight actually because of that plastic gasket that probably rubs against the tube.
I'm wondering whether the tightness caused by the gasket might influence this but at the same time it is the original one (I guess). I doubt that they would have made such a watch with a poorly designed gasket. The case is a compressor btw.
Edited by Chopin
The crown gasket should not affect the location of the movement in the case if the parts are orientated correctly.
Here's a picture of mine. The dial looks similar. It has a big 16-sided screw-down bezel on the front which keeps the crystal down. It looks like it should have an inner bezel, I made a half-hearted attempt to remove it but it didn't budge so I just polished the crystal in-situ.
Will look for it and have a closer look.
Jet @anilv thanks for the link. Mine is slightly different. There is no thread inside the case and the glass sits firmly as it should thanks to the gasket. I see yours has/had a gasket as well.
There are some photos of my model on the web and it looks similar, no bezel. I just can't seem to see whether there's something inside holding the dial/chapter ring (it seems like there isn't).  Even the glass is identical.
Here it is.
https://www.catawiki.com/l/29115339-tissot-t12-automatic-women-1971
Still wondering whether it might have had a tension ringed crystal but even with the gasket in place I don't know if it would be the desired fit.
Weirdly I see the one in the auction also has a very small but visible gap between the ring and the glass/case.
Edited by Chopin
Looks like I'll be wearing the dunce hat.
Problem solved and it was a no-brainer but somehow it only hit me now. The case clamps were flat and as you know they (usually) need to be slightly at an angle to actually hold the movement against the case.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
