Replacing Shock Spring On Bulova
Hello,
Hope everyone had a great holiday. I was working on a Bulova Oceanographer auto-winding day/date (11ANACB) watch and lost the setting lever. That was only the beginning because after I continued with the overhaul I broke one of the shock spring legs from the dial-side. when I went to replace the jewel the spring jumped out and is lost. I have a Bulova  11 BLC that I took the shock spring out of but I cannot get it to stay in the oceanographer movement. Does anyone have experience with this? I was thinking I'll probably have to get a whole new working Bulova 11 ANACB just to get the setting lever and just as importantly the shock spring for the lower plate. Dashto watchparts has the setting lever and its also on Ebay, but I can't find the shock spring anywhere. So...I wanted to get some feed back before I go ahead and buy a not-so-cheap Bulova Oceanographer just to harvest it for twio parts--especially if the skill set for replacing a shock spring surpasses that of a neurosurgeon. Maybe I'm better off just replacing the whiole bottom plate shock system and all? Please weight in on this one!
Here is the watch itself:
And the problem:
Put one side of the hinge into it's locating groove. Cover movement with clingfilm.
Then get a piece of sharpened pegwood to hold it in place while you press the other side into it's locating groove with another piece of sharpened pegwood.
Or step 1 above then place a small amount of rodico over the spring leaving the hinge exposed while you press it in with your pegwood.
Good luck.
I haven't worked on them enough to hate them, but in my limited experience, I find Bulova's difficult to work on. This particular model also has the "lifetime mainspring" that  even has written on it "DO NOT OPEN". I think that the spring I was trying to use is not the right size because I managed to put it back into the donor watch with no problem--Looks like I'll have to buy a donor watch (not that cheap)....Now THAT I hate.
JC
Edited by noirrac1j
PM sent, new shock spring forthcoming.
For those who may have found this thread by searching for a similar problem, here is a very basic KIF primer, they are actually quite sensible and logical:
KIF shock springs come in several incarnations, first thing is to determine which style you need.
Trior:
Elastor:
Satellor:
Ultraflex:
They can look a bit similar if you haven't dealt with them a lot (and if you are reading this, that is likely the case), so try to find a reference for your specific movement if possible. If not, you will need to measure the old spring.
Replacements are ordered with the style prefix, (1=Trior, 3=Elastor, 4=Satellor, 6=Ultraflex); followed by a size reference (1=1.30, 2=1.60, 3=1.90, 4=2.10, 6=2.30) My observation is that sizes 1 to 3 increase by increments of 0.3, and 4+ increase by 0.2
The complete part number will be style-size e.g.: 3-2 will be a 1.60mm Elastor
Which is the part we need in this case.
The Bulova-KIF reference material I was able to find did not include either the OP's 11ANACB or the 11AOACB that I was seeking originally. By checking Bulova service manuals, I was able to determine that these two used the same lower setting (112) as the 11ANACD which is listed in this reference, and uses the 3-2 KIF spring.
KIF_Bulova.pdf
    • Thanks, ManSkirtBrew.  I started looking for a setup like yours and ran across this.  It was about half the price of the JKA Feintaster (depending on what auction you were in), and it's a Bergeon.  I bought it because I thought the price was fair (eBay - Buy it now), and I'm a sucker for vintage tools. It also has a table, so it should be easy to use for measuring jewels. I wonder if the the contact points can be changed out. Bergeon seems to manufacture new tables and accessories for the contemporary dial version. What do you guys think of it? I'm sorry this post seems to have taken a detour. I'm new here so let me know if I should start a new topic.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
