I have acquired an oldish Aria quartz watch. It's quite nice, so would like to fix it up to wear. The problem is, it's losing time, about 15 minutes a day.
I've fitted a new battery, not the correct one, it's a 626 instead of a 726, but it got it running.
Any ideas what could cause this?
A loose cannon pinion is a common cause. With a quartz module normally you can't tweak anything else except doing s full strip down and service. It can be more practical to replace it.
Hi  What make is the module, there will be a caliber number and  makers mark .  It would be helpful if you could post a picture of the watch front and movement.   The fact that even with the wrong battery in it runs is good to know. As Yankeedog mentioned the lubricant could be gumming the works up or is of the wrong consistancy, in which case jdm is right strip down and clean and re lube. If the watch is still the same after that its a replacement module.
13 minutes ago, ftwizard said:
Thanks for the replies.
Any tips on stripping it down?
I've done dozens of mechanical movements, but never a quartz.
Nothing special really, the rotor is magnetic so keep an eye on it. Do not wash the circuit or the coil. There are few walk through topics on quartz in the dedicated section.
Hi  I was working on a Miyota 2N50 with the same symptoms and after cleaning I found that the small gear driving the hour wheel/cannon was running in a worn bearing and during the cousre of an hour could loose 15 min as the wheel was at times failing to drive. Now two factors determine the next course of action, the module was obsolete so no parts , replacement was the next and a ronda 1032 was purchased as a replacement. Economics are also a factor.
If you wish to clean the movement,  First remove the circuit assy and the coil ,dial and hands. Having removed all the add ons from the movement then immerse in Naptha (lighter fuel) and clean dry on a tissue under a lamp. Once completly dry re assemble and test with a new and correct battery or an external  supply of 1.55v. It would be helpful if we knew what the original module was, what make and calibre.  There is no need to strip the gears out to clean unless you wish to or the state of the module requires it. Be careful some of the plastic units cannot be dismantled only replaced.
The movement is an ETA-ESA 965.102
It seems the problem was the minute hand catching on the raised numerals. I corrected that and it was running fine. Of course I decided to take it apart anyway. Cleaned, reassembled and oiled.........and now it doesn't work at all. The wheels are free and run ok. I definitely didn't damage anything during the work.
I put a meter across the coil and it seems to be getting a pulse that reverses phase each pulse. I tried putting a compass near the coil, thinking it would reverse polarity with each pulse, but it didn't. Not sure if that would work anyway.
Any tips for testing?
Hi  a common problem and with watches running erraticly one of the first thigs to check, loose hands and catching hands.  If you are getting a pulse at the coil , If you can see the rotor is it stepping if so look at the driveto the hands. I use a bespoke tester for quartz units which has its own 1.55v supply and a series of led,s for diagnosis purposes. There are cheap pulse and coil testers out there from India and are internaly rather crude.   Before purchasing this one I made my own unit which is still in use. Look up Mike Catt quartz watch tester which is a self build unit, mine is based on that.
I’m at a complete loss now. Here’s some readings from the movement.
Pulses every second 0.025v
Coil resistance 230k ohms
Cool to stator 1.7 meg ohms
Still the rotor doesn’t turn. I’m baffled.
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
