Good morning I have a German wall clock which has a reverse movement. It has U.T.S. Quartz made in Germany and the only number I can find on the plastic is 1503   800455
Would appreciate any help where I can buy a replacement part
You can buy similar movement on Ebay .  I would use a non ticking movement. Check the fitting for the hands and the height of the  shaft that goes thru the plate.  Here is a link to one . Has the worlds longest adress :)
https://www.ebay.com/itm/Silent-Wall-Clock-Quartz-Movement-Mechanism-Hand-DIY-Replacement-Part-Set-Filmy/233173076941?_trkparms=ispr%3D1&hash=item364a32cbcd:g:mPUAAOSw-iZcCKWq&enc=AQAEAAACYBPxNw%2BVj6nta7CKEs3N0qXbliNMphRIauZ3EW6ug4hUWbl4JkWK98rOpvtioK2K86cdGOVcTCEcC6FmSRO5pjRdb8LTyvukSy1Gm0bWvvTPPTJu1mR1ezVtW8OSx8VHd3i%2B5i6dNiBzHTAjIgi3c9gDo8QQMlfrkDaqrjkSAVM1G2kuHCYsmCYPeSPosr5OoC8DwgWrJR9eS0%2F5chRfoaW3PGAUVFZYb9IzZnsHNpIs4mIfao%2BoYq0M9%2B5pRIEWIiV%2BLOByebZrLw7vI35NT91dnFGtEuXkquT8Qksv%2FVasi%2Bx%2Bcee%2Bc9Hy7s%2Fq0Y3Cg3ckZeowdgFoRhwCGMb9VAFsFCBbVMWCinyZ%2Fd4qYDUEPa%2FbzPQcwuYdVuC9WFt%2BzxiGLHmDHSWSQx2bn1BLjps1JgZBZMb85ZILE9lQLB%2FDF2sAnhmf%2FoEO%2BzuXpcMli5ZCvkdsAZrqQlEDUebS9N7fkAmNX7Jfsy3LyGhRqb4OPuZKam%2FtQBqeOGvg%2BfRiwcBAr2WB%2F%2FJIy5qRt0DL7z7ESVfV0jypm0k2JvakQ8np90qE%2F7LM%2F8OzJsaoCm%2FLhJN%2BECXZKoyvPyRwCD6ZVTOMiMowugTYZz3vByI4Nrgc9u3SjDmCDCzGKE05UODyflWjoPmE7vDaGnTWDQsAQwdBH6qs%2FloO3Kx4G0wfktDpntzVloZQpukcpSXrWouEC9igkfiEAgWl1CK4a%2Bc6nyrnBTuCV6VYHMM5Yhqe6udVfr1Bpr1NQO4LXR2MzFgu%2B7ckbkep5yZT41xkzDTkTc1See%2BH8wzlk5J2YpE4ctEj&checksum=233173076941f01eed12e5664c0484efaf16ff846a57&enc=AQAEAAACYBPxNw%2BVj6nta7CKEs3N0qXbliNMphRIauZ3EW6ug4hUWbl4JkWK98rOpvtioK2K86cdGOVcTCEcC6FmSRO5pjRdb8LTyvukSy1Gm0bWvvTPPTJu1mR1ezVtW8OSx8VHd3i%2B5i6dNiBzHTAjIgi3c9gDo8QQMlfrkDaqrjkSAVM1G2kuHCYsmCYPeSPosr5OoC8DwgWrJR9eS0%2F5chRfoaW3PGAUVFZYb9IzZnsHNpIs4mIfao%2BoYq0M9%2B5pRIEWIiV%2BLOByebZrLw7vI35NT91dnFGtEuXkquT8Qksv%2FVasi%2Bx%2Bcee%2Bc9Hy7s%2Fq0Y3Cg3ckZeowdgFoRhwCGMb9VAFsFCBbVMWCinyZ%2Fd4qYDUEPa%2FbzPQcwuYdVuC9WFt%2BzxiGLHmDHSWSQx2bn1BLjps1JgZBZMb85ZILE9lQLB%2FDF2sAnhmf%2FoEO%2BzuXpcMli5ZCvkdsAZrqQlEDUebS9N7fkAmNX7Jfsy3LyGhRqb4OPuZKam%2FtQBqeOGvg%2BfRiwcBAr2WB%2F%2FJIy5qRt0DL7z7ESVfV0jypm0k2JvakQ8np90qE%2F7LM%2F8OzJsaoCm%2FLhJN%2BECXZKoyvPyRwCD6ZVTOMiMowugTYZz3vByI4Nrgc9u3SjDmCDCzGKE05UODyflWjoPmE7vDaGnTWDQsAQwdBH6qs%2FloO3Kx4G0wfktDpntzVloZQpukcpSXrWouEC9igkfiEAgWl1CK4a%2Bc6nyrnBTuCV6VYHMM5Yhqe6udVfr1Bpr1NQO4LXR2MzFgu%2B7ckbkep5yZT41xkzDTkTc1See%2BH8wzlk5J2YpE4ctEj&checksum=233173076941f01eed12e5664c0484efaf16ff846a57
Edited by rogart63
You can always trim an Ebay link or most others from the first question mark to the end.
Note also the OP needs a reverse movement. He can't fit another.
Ooops . I missed that he needed a reverse movement . But sure there is such on Ebay to .
