I have the watch shown in the pics, which I purchased in 1998.  The capacitor has been slowing down for years and finally won't hold charge.  (Pretty amazed it lasted this long).  All the videos I see online about replacing an Eco-Drive capacitor look similar to a typical battery replacement, but this one's buried.  After getting the back cover off, I removed 3 screws which I hoped would allow the matal cover to be removed, but it looks like there's a lot more to it.
This one may be above my pay grade, but I wanted to ask, maybe there's something simple that I'm missing.
Thanks for any help you can provide!
You are going to have to take that back plate off but you've done the right thing stopping when you were unsure.
We need to try and find the movement reference. This is probably around the area I have marked in your picture - I just just about mae out Citizen and Japan but there's too much shine on it to see a number reference. When replying also include a copy of the case back as that can sometimes have useful information stamped on it.
It's held in place by the many side tabs, lift all around and out it will come.
Thanks for the reference.  I ordered the new capacitor.  I have a sentimental connection to the 2 decade old watch, so it will be very rewarding to give it new life.
If you  remove the module from the case (stem release is clearly marked, a good Japanese habit) you will be able work more comfortably using a mov't holder ($2) and clean thoroughly the stem tube and crown, and lightly lubricate the stem body (Moebious HP-1300) and gasket (silicone grease), that's always good to do.
10 hours ago, yankeedog said:
after you replace it , full sun for several hours.
Sun?  What is this sun you speak of?  I'll have to keep an eye out for it.
:biggrin:
Well, thanks all for the help.  Unfortunately this endeavor was doomed from the get go, way out of my league.  A friend of mine, who actually is a professional watch repair guy, sent me a tech sheet with the numbered steps to disassemble & reassemble the watch.  You have to remove the face, hands, etc, a total of about 20 steps on both sides of the movement, before getting the capacitor out correctly.  i was able to get it out, but not able t get the new one in without removing additional parts, and then I went too far, which resulted in tiny wheels lying all over the place.  I spent a couple hours on it, but hit a wall.
I have no idea if this is something Citizen would put back together without charging me an arm and a leg or what.  Not a crisis, it's just a watch.  I'm just disappointed I wasn't able to do this.
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
