Waltham Mass Balance Spring
carlos123
Hi all,
I’ve just stripped and rebuilt a Waltham Mass pocket watch, which was running previously but didn’t keep time and kept on stopping. I’m on the final assembly stage and trying to install the balance wheel with little success [emoji45] the spring looks to be too big for the fixing point as well as the regulator being higher than the actual spring[emoji848] I’ve not messed around with it other than an ultrasonic bath and some oil, and wondered if someone could offer some advice please? This is my first proper go for a full strip down so hopefully I haven’t broken it...
Thanks in advance
Carl
In the picture, the balance wheel seems laying on top of the mainbridge. Should stand a mm or two above the plate.
Check if the lower jewel is intact?  Lower pivot not broken.
Show pix if not sure.
Regards
Edited by Nucejoe
Lower metal bushing
Have you tried it in cock down position?
If the fork checks out( jumps left to right and back when nudged ) and nothing rubs, upper pivot intact, desent endshake. Perhaps roller has turned on staff which throws impulse jewel out of beat, that to explain the stud being far from stud holder.
Edited by Nucejoe
Check if the roller has moved.
Check lower endstone? Did you forget to instal the lower endstone or broken.
I left the endstone in place when I cleaned it all. The balance spring looks offset when fitted as it looks like the anchor point is too close to the centre, the spring doesn’t really engage with the regulator either as it’s too high compared to where the spring lays.
A picture of the other side of the balance Wheel and hairspring be nice so we can see the hairspring properly. Then the serial number so I can look up and see what kind of the hairspring you're supposed to have. Then before you disassemble did you notice any problems with the balance wheel and hairspring?
Hopefully these photos are good enough and show the spring position?
I find the pictures misleading I had assumed that that was in 18 size pocket watch? So apparently it's a 14 size export grade watch. Both Elgin & waltham exported a lot of watches to Europe sometimes they had their name on them sometimes they did not that are often mistaken as English watches if their name is not visibly on them.
Then your picture looks like a slightly distorted outer terminal curve for a flat hairspring unfortunately according to the pocket watch database it's supposed to be in over coil. Then looking at where the regulator is in your first picture it looks like the pins are too short for flat hairspring and to close in it's definitely an over coil hairspring which you definitely do not have.
Look carefully at the balance wheel and see if there's a serial number on the wheel itself. Usually but not always on American pocket watches the serial number has been scratched in the balance wheel we can see if somebody swapped balance wheels?
https://pocketwatchdatabase.com/search/result/waltham/6980192
Familiarize if you will, with the shape of a breguet overcoil . This HS may vibrate with the wheel, either the overcoil uncoiled or somebody just fitted a flat HS and passed it to you.
At worst you would need to replace the HS with a proper breguet overcoil and vibrate.
Regards
The stud is not in place in the photo??
The serial number on the balance wheel is not stamped. It's usually hand done sometimes it's really hard to see and occasionally it's not there at all. You'll find it on the arms either on the top or the bottom. Then that hairspring looks nice and flat which is unfortunate because it looks like from the pictures you should have an over coil Hairspring. So if you can find a serial number on the balance it would be nice . Because that way we can figure out whether you just need a hairspring or balance complete either of which will be hard to get for 14 size.
Just found the number, it looks like 6980 192. Very difficult to see
Good news you have the balance wheel for your watch bad news you don't have the hairspring perhaps? So if you're really good with hairspring manipulation you could possibly reform the over coil but that is a lot of work and the other minor problem is this assumes that this was the correct hairspring in the first place which it may not be.
2 hours ago, carlos123 said:
Would it be viable to reshape the spring? The watch did intermittently run previously prior to cleaning, however it was running way out with no adjustment which is probably down to the incorrect spring anyways...
Yes, if the flat HS vibrates the wheel to the right beat, it also will as overcoil. I recommend  reshaping to overcoil.
1- Moung the stud on stud holder.
2- instal balance ( hairspring attached) on the cock.
3- As if you are sculpturing , follow the curve of an overcoil from a picture as your modle. To come up with a fit within the space available above the balance wheel.
I hope I am making sense.
Easier done than said.
Edited by Nucejoe
Instal cock balance on mainplate.
It should run slow without the adjustor arm. How inaccurate did it run without?
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
    • Probably easier to get a complete new movement - but CousinsUK list it as discontinued. Maybe someone on here knows a substitute movement ?
    • Any other thoughts on how I can get a replacement coil? Any “hidden” or unknown physical shops (in Australia or elsewhere) that might have them in stock (but not always online)?
