Hi everyone!  So I’ve just picked up my first Omega and to be honest I am very excited to start this project!  It’s an Omega Chronostop with a broken balance and tangles mainspring but otherwise mechanically seems in good shape.  I’ve accumulated all the pieces necessary to do the repair mechanically so now I’m on to the case.  I’d like to get it restored back to original but not quite sure where to go. I brought the case in to my nearest Omega dealer and they said it could not be sent to a service centre to be re-done as I dont have any original paperwork.  Since there is a sunburst finish on the case a lapping machine would be ideal.  Can a person send in a case independently from a dealer to Omega?  If not, can anyone recommend a case restorer that could bring it back close to original finishes?  Any help would be greatly appreciated!
Did I read that correctly, omega said that they wouldn't service it because you didn't have any original paperwork.
As for the case refer, there is loads of people all over the world doing it.
As for it as it stands, I had one in a similar condition, I cleaned it serviced it gave the case a polish and its looking good, no original paperwork needed...
Only the entire watch. Omega lists service (high) prices on their website, for the rest they would give a stellar estimate. There are very few high level case refurbisher around.
Edited by jdm
Thanks AlexiJ1 for the recommendation and everyone else for the input.  Replateit.com did come up during my search and I was hoping someone here would mention their quality of work.  I think I have decided I will send it to Lewis Watch Co. in Australia, his work looks exceptional from what I've seen.  antonyh, yes they said they would not accept it due to no original paperwork.
That is big BS, papers are never a requirement and it would be unreasonable to expect everyone has them. They were cherry picking work and come up with an excuse to send you away.
  • 7 months later...
Hey everyone!  So I thought I would follow up on the progress of this project.  I got the case back from being refinished and it turned out really well!  I gave the movement a once over and a service as it obviously has had a fairly rough life.  There were a number of broken wheels, particularly the chronograph runner and drive wheel, 4th wheel pivot was bent and  the hairspring was torn and the balance pivots where both broken.  Topped it all off with a new crystal and this is the finished product.
    • We need photos, age and price probably just a rough estimate.
    • Hello all, I am looking for guidance on some Cyma watches I am selling please...Year made approx and possible worth if you could? Also I have a man's Cyma that has numbers stamped around the case where the strap bars are and wonder what they are please. Thanks for and help given. Steve
    • I agree with hector it's probably the regulator curve, it almost always is on these movements. So i work on these movements a lot and iv'e managed to fairly consistently get them running at like 50 degrees more amplitude than that with deltas in the 3 range and on the wrist deviations of sub 1 second a day. They ALWAYS require work to get there though. The main thing is shaping the regulator curve and this is really finnicky and definitely something you practice on a movement you don't care about when you're new (I'm still new) but if the hairspring is flat and the coils are evenly spaced and the regulator curve is properly shaped and it's pretty wild how accurate these movements can get.  But, it does sound like your regulator curve maybe needs a bit of reshaping. You can easily mess up the watch learning to do this so warning if you don't want to live with your current results but I"m not an expert, it's just speculation but there's a pretty easy way to check.  This is a good video showing how to see if your terminal curve is properly shaped. Just make sure the regulator pins are open when you test this.   He takes off the balance wheel to shape it. I do it with the movement disassembled but the balance on the mainplate. I use a homemade tool from a sharpened dental pic to do the adjustments (Tiny tiny TINY adjustments) and i use the regulator pins themselves to sorta brace the spring against to bend it very tiny amounts and just keep checking it by moving the regulator arm down it till it stops moving the hairspring. Taking off the balance wheel over and over again is a good way to slip and destroy your hairspring and will make the process way slower. I try to avoid removing the balance wheel from the cock it on these movements due to how difficult it is to get the hairspring stud back into the balance cock. It's super easy to slip and twist your spring then you got way worse problems.  Since these are mass manufactured and unadjusted the regulator curve is NEVER perfect but once you learn how to reshape them it's pretty easy to do and you can get REALLY low deltas with really low positional error and pretty remarkable accuracy.  Definitely with it powered down and the balance on the movement with both balance jewels in place look across the spring to see if it's perfectly flat, then check the regulator curve how he does it in the video. I would bet money even if it's not your main issue the regulator curve is not ideal also.
    • Thanks. Damn, first breakage. This picture of the movement is from the sale listing.
