Timex 1970 Electric Diver - built from parts
JerseyMo
Timex 1970 Electric Diver  - Built with a combination old and NOS parts.
old - Caseback, movement cover, bracelet, eleapsed time bezel ring
NOS - Dial, hands, movement, stem\crown, crystal
Althoguh the dial came with correct hands, the lume had cracked over  time. So with a mixture of white glow in the dark hobby paint and some clear nail polish I replaced it.  It does glow for a few seconds. :)
The rest is the typical parts assembly so not much to talk ablout there.  But, what to do with the strap or bracelet?   I found this NOS black plastic bracelet in one of my parts bins and added the "Timex" clasp for a final touch.  Brite was a supplier to Timex so the look and fit is great.  Time keeping  has been dead on for 4 days now.   Going to be hard to let this one go.  But than again I built it to sell so on to the next project.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
