Can This Balance Be Rebuilt? Waltham 6/0 1942 Military
I have a Waltham 6/0 1942 Military watch that has a bad Balance. Regulator is missing and Hairspring is fouled. Finding a replacement is almost impossible(at least for me) so I'm left with attempting to rebuild. All comments and advise appreciated.
Many may call it a goner, I have however recoiled many. It is thick and easy to work on. Some advice if you decide to give it a go.
You need finer tweezers than what you are holding in the pic.
Unpin the h/s off of the stud.Remove the h/s. Insert a safety pin through the collets hole and pin the h/s on a white sheet of paper.
Start from the collet outward.
Do not work on it more than ten mins at a time. Give yourself time to think about what you done and what is to be done next.
Keep in touch with me as you proceed.
Best regards
