FHF Robert 8.75 Ligne
AJH
Hi I am new to this forum and am looking for a balance staff (or balance) for an unnamed movement, the only markings are the Swiss patent number 51482 and a serial number 4903.
It is a manual wind, no seconds, I have trolled through Ranfft and think this may be a FHF Robert 8.75 ligne, can anyone shed any light on this and where I may source parts, ebay and Scotwatch don't seem to have any.
Thanks
Alasdair
Hi clockboy, I have searched balancestaffs too and they don't have the FHF Robert listed for 8.75 ligne so I will need to go with your suggestion and measure the old staff. I don't have the tools or experience yet to replace a staff so will have to take it to a watchmaker I guess.
I would still like to know if my movement ID is correct...
Thanks for your reply
Alasdair
I think your identification is correct ... in which case this FHF Robert is the same as the Gruen 100 / 101. This takes a balance staff with the Ronda number 1144.
If you go to the Cousins page https://www.cousinsuk.com/category/filter/ronda-staffs-by-ronda-number you can search for balance staffs by Ronda number and I see they'll do you a pack of 12 for £8.95. Worth searching other suppliers too.
Alternatively if we're pretty confident with the ID and now knowing that your FHF = Gruen 100 /101 (which also according to ranfft are the same as the Gruen 620, 623, 626, 627 as differences not known between these six models) it could be worth a search on a site like ebay for any complete movement going that has a good balance.
  • Confused 1
4 minutes ago, WatchMaker said:
Hi @Nucejoe ... if you let me know why you've left a 'confused' emoji I'll try and clarify! You may want to look at http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Gruen_100 first though.
It won,t let me choose the emoti I like, sometimes I get to choose the medal other times the confused emoti or one of the other choices.I mean approal by all and the point the post gets. Sorry thats the best I can do and that is despite rather costly , paid vpn service. Sorry Sorry.  You did ID the movement, the one point is my thums up.
Best regards joe
By chance I found this on ebay which is pretty lucky, it is on it's way from New York as I type, fingers crossed it is the same as mine.
Thanks for your help, really appreciate it guys.
Alasdair
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
