Afternoon gentlemen.
Does anyone have any idea where might get a replacement balance complete with balance cock for an FE 233-60 movement, the one I have is a complete mess.
Any pointers appreciated.
Jon
1 hour ago, rogart63 said:
Have some cupillard parts . SO could have. Bridge i have but not sure if i have a balance. But will have a look.
Thank you.
20 minutes ago, TheFixer said:
Thank you.
No balance except one with a little bent hairspring . Think it could be fixed . It's inca bloc  and has a smooth bridge.
My hairspring fixing is not good, but I suppose I could have a go.
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
