There was talk tonight at a club I attend of possibly buying a 3D printer. I can think of movement holders and parts trays as obvious choices, but what else might one be useful for in a modern watch workshop? Also if anyone has any experience of them and has 'must haves' and 'must avoids' lists that'd be great!
I've got the Flashforge Dreamer 3D printer.
I've  not really made much with it for watchmaking, myself, but have used it for many other things including making parts for my 1970s electro-mechanical pinball machine that were not obtainable any other way.
A very important thing to think about when buying a printer is the size of the print bed as this dictates the biggest thing you can make, usually cheaper machines have smaller print beds that will limit the size of things you can make.
Try and buy a printer that is fully enclosed as it eliminates the problems of cold drafts cooling the print too much between layers that can lead to print failure.
You want a printer that can print from an SD card not just from your computer. That way you don't need to leave you computer on when you are doing an 8 or 12 hour print.
Choose a printer that parts are readily available for and that has a big user following, as this will give you more help with finding the best settings.
Look at what software comes with the printer and think about what other software you might use.
I design most of my parts on the free software sketchup, but purchased simplify3D for doing my slicing as it produces better results than the software that came with my printer.
Printers are somewhat noisy and do give off plastic fumes so best if you don't need to leave it running in a small enclosed room.
That should give you a little to think about.
I have a monoprice voxel. It is limited in features compared to others but works out-of-the-box and was a good price. I wouldn't bother with a 3d printer for parts holders and the like. There are a few nice designs on thingiverse but really it isn't worth the bother. Injection molded supplies are going to be better quality and you can buy a bunch all at once instead of one waiting to print them out one at a time.
Where it may come in handy is when you need something in a specific shape that you cannot buy. But keep in mind you will need to learn at least some basic CAD design. I use Moi3d which is excellent but there are cheaper alternatives.
I've used my 3d printer to create different adapters and holders where I needed an exact shape. For example, I was bending a strip of brass and was able to create plastic bending clamps I compressed with some pliers. I was able to figure out the exact inside and outside curve I needed and print to match. The nice thing about the 3d printed parts is you can use glue to attach whatever you need to it without worrying about having to damage the print when removing it as you can always print a new one.
For me its more of a general shop resource vs watch specific - something to be pursued if you like making things.  I've not yet thought of any watch uses that it would just perfect for, but in general it opens up a lot of possibilities
I bought a Prusa recently, it was supposedly highly rated.... look at all the useful stuff I've made!   What a disaster!
Anyway, I'm down on this crappy printer, I do keep working on trying to solve the bugs, as the potential capabilities it brings to the shop are really quite exciting.  Prusa griping aside, check out the second image - a yoke for a dynamic balancer I'm making.  A part like that would be near impossible except by casting and a pattern.   Aside from making a pattern and doing a casting being a huge amount of owrk, its also unlike a casting in that you specific the "fill" percentage so items end up very strong and light - there's no other way to do things like that (3rd photo of partially printed parts so you can see the fill).  In the photo its a 25% fill - interior is only 25% material
DDgH40r.jpg?1
Edited by measuretwice
Thanks everyone, food for thought and I’ve learned some by reading your posts. More research needed!
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
    • Seems like he doesn't have the micrometer cap  attached to the spindle so he can only push down but cannot pull up? If the cap screws into the spindle I guess you don't need the spring? I only have a "normal" Seitz so I really have no idea.
    • Do you have a part number for the bearing shim lock tool?
    • Yes in my opinion the 3/4HP is plenty but it’s your decision & yes it does come with speed control but foot operation so my reason for changing to potentiometer was because my leg shakes so it was like me revving the lathe & anyway I prefer to set the speed. I & a few others that I recommended the motor to run a Pultra 10mm lathe so if you have a 6 or 8mm B & L then it will be plenty, if you have seen any of my videos you will have seen that when using a graver I run quite slow without any problems. Dell
